Notsotalltexan
- Mar 21, 2023
- San Antonio, TX
- Winnebago
- View
- MB Sprinter
- MB
- 2021 Jeep Wrangler Unlimited
Try assisting it in mechanically (manually) to get past the point where its binding. It may run in on its own after that point. I can also see Neil’s point about something under the bed blocking the mechanism and you’ll have to expose it to move it manually anyway. I had one with a broken gear tooth and it wouldn’t make it past that spot without manual assistance. But your problem sounds more like binding or a weak motor or possibly a bad controller.Our 2017 Ventana 3709 bedroom slideout will not retract. It moves in about 2" then sound like the motor is under too much strain to continue. If you press extend, it moves back out 2".
Help!!!
Laurent
intellitec.com
I would buy the KMG 0159 controller, not the Intellitec, as they discontinued the Intellitec years ago for LMC30, and then discontinued the LMC30 (aka C-Storm controller), and now use the KMG 0159. So the KMG 0159 controller is the most recent one Newmar uses as far as I know.Greetings--
This morning our bedroom slide would not come in. The motor works and moves about an inch in and stops then iIcan move it back out. I removed the two-wire connector from the controller and plugged it back in after only a few seconds but no banana, Then I unplugged the multi-connector for a few seconds and plugged it back but still no dice. Then I unplugged both for a few seconds and plugged both back but again the same. So I unplugged both connectors then came in, removed all our stuff under the bed and removed bed storage base and could see the motor and shaft. All looked okay without any obstruction. There are two wire nuts I checked which were secure. About ten minutes had passed so I went out and reconnected both to controller, pressed IN and the slide came in as usual.
The time before I recall I waited about ten minutes before reconnecting both. Maybe that's why it worked. As Rich mentioned, Newmar had issues with the controllers they installed from '16 to '18. I'll check eBay for the Intellitec controller Rich posted. Thank you all for your help.
Today we're headed to a National Forest campground called Prospector near Dillon, CO right on Dillon Reservoir. Water available only. We've decided to leave bedroom slide in until I get a replacement controller.
Laurent
Thats the model Newmar sold me in 2021.
