Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
yup, hook it up and turn on the water and watch the crud flow out. That’s why they say you should have the black tank dump valve open to avoid an “unsanitary condition” or something like that. I have a clear 90° elbow more or less permently mounted on the coach, mainly because of the horizontal arrangement of the OE dump plumbing, but its also good to be able to see what’s coming out of the tank.There’s no other valve to open? Just hook it up, turn the water on, and it will fill the blank tank?
Yep, as I was watching the black tank monitor filling up, I pretty much envisioned the same thing as what you have. Great idea, and very nicely integrated!There is an air gap and a back flow preventer to keep any contamination from occurring. I have a setup in my wet bay to make it easy to rinse the black tank which I do every time I dump. I installed two more back flow preventers in the short hose connection to quadruple the protect against contamination. View attachment 20229View attachment 20230View attachment 20230
Yep, I leave the black tank valve open, to keep it from filling the tank, and flush till I see clear water coming through the clear elbow we have.There’s no other valve to open? Just hook it up, turn the water on, and it will fill the blank tank?
Wait........why do you ask those questions, in that way?There’s no other valve to open? Just hook it up, turn the water on, and it will fill the blank tank?
I do this too.I like to use it to fill and flush the tank, watching the tank level closely of course.
To be honest, I've never used the tank rinse, so in that respect I guess I'm a newbie.Wait........why do you ask those questions, in that way?
I ask, because it makes it sound like you have zero experience with black tanks and thier "normal" usage.
Roger
But it's never been necessary. I usually dump the black tank and then let the grey water flow back up into the black tank until it equalizes. Then I dump the black (now full of grey) again. Then shut the black tank valve and finish dumping the grey.
So in a manner of speaking, it's getting flushed out each time by default.
