How do i find the weight that i am actually towing with my 5th wheel hitch?
Radioherd
Hey All,
We jumped on the cat scales yesterday and got the following readings:
Steer Axle: 5380
Drive Axle: 7460
Trailer Axle: 12760
Gross Weight: 25600
What i really need to know is how much weight is my hitch actually dealing with - i know its not as simple as adding the drive axle to the trailer axle (as that would include some weight from the back of the truck), so how do you actually calculate the weight of the 5th wheel only? Do you have to disconnect on the weigh scales?
At a CAT scale you can re weigh, within a certain time limit, for no additional charge I believe.
I have just dropped the jacks on the scale and taken the load off the hitch with the rear wheels of the truck off the scale. That way you can also determine the pin weight.
Ok thanks all - we are at 16480lbs
The GVWR of our rig is 16,995lbs - so basically we have just over 500lbs before we are at our safe limit yes?
Rated limit is meant to be interpreted as safe limit, but it‘s also important to consider it a legal limit in terms of liability and culpability. If over the legal limit and involved in an accident, one could easily imagine being cited, fined, and/or sued, as well as having possible problems with the insurance company. I’m sure there is a safety margin and your rig can probably handle more but to me it’s just not worth the risk.
Might look into a haul gauge.
I’ve been using for several months and it is 98% accurate when compared weighing on a scale.
Interesting little device. Read some reviews about it. The accuracy varied. It can be 10% off.
I used mostly the 20% rule. 20% of our total 5th wheel weight for the tongue weight.
It is not accurate, I know, but gave me a good idea.
as they say, your results may vary.
I used it to get the tongue weight and the GVCR. it can't give the trailer only weight, so you have to do the math manually, combined weight minus the truck weight.
On a recent trip from L.A. CA to Fort Collins CO to take my kid to college, I had a cargo trailer loaded with all her furniture and possessions, I was concerned about overloading the cargo trailer.
I ran the app without the trailer, with myself, daughter, and her luggage in the truck and got a weight of 5,420 lbs, then ran the app with the Cargo trailer attached and it weighed my SUV and Trailer with a GVCR of 8,876 lbs, so 8876-5420 = 3,456 in the trailer. Trailer has a GVWR of 4,120 lbs., SUV has a GVWR of 5,871 lbs.
The app gave me a tongue weight of 276 lbs.
took it to a local weigh station,
The scale gave me a truck weight 5,397 lbs. and a trailer weight of 3,325 lbs. combined weight of 8,722, a difference of -154 (so less) than the app.
Tongue weight was 275 lbs. on the scale., so nearly dead on.
it seems to give a bit of a higher reading than actual weight, however the way it does the weight reading is some type of algorithm based on engine load coming from the ODBII sensors. so, if I was on a slight incline during the test, it would indicate a higher reading, and if on a decline a lower reading.
I believed I was on pretty level ground but based on the recent "hurricane" that happened in my area, I can clearly see based on the flood run off, that the street was on a slight incline, so that justifies the minor differences IMO.
