Replace old lights with LEDs
Komfort 282
Livingston, MT
Komfort
30'
Is there a method or hack to replace my 2007 Komfort 282 trailer light bulbs with LEDs? I think the existing lights are halogen sucking up tons of battery power, and i haven't found any LEDs that can work. Thank you.
We purchased 12 volt LED fixtures and replaced all the overhead lighting in our 2007 coach. I initially had switched out the bulbs but was not happy with them. This is what we bought for main overhead lights. I also replace the light over the kitchen table, and over the kitchen sink and bathroom.
Amazon product ASIN B09KMGWFW6
I think you can just replace the bulbs. You will match up the bulb to the type you have now. I have not done this as we sold an older 5th wheel and purchased a new unit and it has all LED lighting. I’m sure others will have input on this. Good luck.
This is the way I do it!
I would prefer going back to incandescent though. Seems reports are coming out that LEDs are causing eye problems!
This is from a home depot contractor pack of two, the other one is in the bathroom.
I power them with the inverter that is never shut off. I have used these on all mods on trailers for a good 8 years.
You can buy replacement LED bulbs cheap on Amazon:
Or buy complete new LED RV light fixtures:
Or get creative and use any 12v LED fixture that fits the need:
I’ll use these to add light in various baggage areas:
I would guess that all LED fixtures and bulbs come from the same types of factories in china with the same standards and processes. They usually claim 50,000 hours. I have yet to see any fail and a very small fraction of the claimed life-expectancy would be adequate so I’m not too concerned.
We use LED for almost all lighting. We stay below 4500 Kelvin. Don’t like the 5000+ K, Walmart parking lot effect, except for work shop area.
And have a dimmable LED if possible .
That's cooooool! Would like to be able to say the same, but my mileage is quite different.
I do have another reason I went 115vac. 24vdc system, but would have kept the converter had I not had my fill of short life 12vdc garbage(not just LED lights).
Regarding LED and eye damage, here is an interesting discussion on blue light and its effects on eyes
I focus on the mention of pulsating causing problems, the blue light is simply the icing on the cake. The built in voltage regulator in 12v lights creates a pulse, as well as dimmer circuits. But it goes one step further! WiFi And cell phones radio waves do the same pulsating.
Thanks Joe for your article.
I changed out all the incandescent bulbs in our T/T for less than $15. There are 12 I think.
This was about 4 years ago and not a single one has failed.
The power they draw is miniscule compared to the old bulbs. I accidently left the light in the bathroom on for about 3 weeks before I saw it and there was virtually no drain on the batteries. (y)
As far as the the pulsing and wi-fi and cell phone radio waves I guess you could just start wearing a foil hat.
Well my design is a little more durable, but yes I have one of those too!!!
I sent this pic to a potential buyer complaining about the power lines being too close to the house I was selling.
Good info, I bought a couple of bulbs that worked in my fixtures and in general we hate them. They are to bright. Thus the need to get reduced Kelvin bulbs. By the same token, I hate the normal bulbs as well because they are to dim. One of the "new" led bulbs has already failed.
I guess I should have mentioned that I’ve only used the cheap LED conversion lights in exterior and basement fixtures. So I want bright, obnoxious lighting in these cases. I use OE LED stuff in all the interior fixtures.
