LightShip - The Future?
turbopilot
Prescott, AZ
LightShip
AE.1 Cosmos
Electric
2025 Ford F-150 PowerBoost HEV
New forum for LightShip position holders. Is this the new "Airstream" for the future? I think so. Took a position 6 months ago.
And here is a long standing thread about LightShip on the Airstream forum where several position holders have participated.
Lifespan of the batteries would be a concern and the cost to replace them. That could have a big impact on resale or even using as a trade in. A 20 year old RV is not uncommon but based on todays batteries this may have a 8-10 year service life. I do like the idea of a powered drivetrain. Diesel/electric would be cool. Once parked the diesel generator could power the coach.
$150,000? hmm seems a bit over priced IMO
Unless the venture capitalists supporting this concept are prepared to sell them at a loss I suspect the price will be higher than $300k. This "trailer" (since this thing is self powered it is really not a trailer) is aimed at the Tesla Cybertruck, Rivian and Ford Lightning demographic. The solar panel array alone is probably worth $50k. Powered chassis maybe $60K. Solar panel array and associated high voltage DC battery is setup to backup your house or back charge your EV pickup.
that's no $50K solar array, that looks to be about 18-20 panels. I had 40 on my home that didn't even cost $50K, I paid $23,000 installed. for 20 200 watt panels and 20 300 watt panels.
I would say at best that is a $15k-$20k setup at retail.
Based on todays batteries and the likely amount of cycles they would receive in a trailer the batteries life would probably be 30 to 50 years….or longer.
Telsa battery warranty is 8 years. If true then maybe the trailer will come with a 30 year battery warranty and that would be a huge selling point.
The U.S. Department of Energy, meanwhile, predicts today's EV batteries ought to last a good deal past their warranty period, with these packs' service lives clocking in at between 12 and 15 years if used in moderate climates. Plan on a service life of between 8 and 12 years if your EV is regularly used in more extreme conditions.
I doubt they’ll make the warranty that long. Some engines last 20 years or more but their warranties are only 3 to 5 years. Warranties are huge liabilities for manufacturers.
A tesla battery probably gets more cycles in a year than a trailer battery does in 10 years. Batteries don’t care much about age. They care about cycles.
Hard to say. We have fleets of 8 year old tesla cabs here. Many with north of 400,000 kilometres. They typically have 12 percent degradation and that’s older technology. And they get supercharged multiple times per day. I think we’ll all have to wait a decade to get a true picture of how the batteries hold up.
Is there air conditioning?
Here are the electrical specifications for the LightShip:
All-electric (L1 Long Range)Battery capacity 40kWh, 80kWh options
All-electric towing range Up to 300 miles
Solar generation capacity Up to 3kW
Off-grid power 7 days (while running appliances)
As you can see they predict a EV pickup that would tow a regular 7,500 trailer 100 miles on a charge will pull the LightShip with EV assist up to 300 miles on one charge.
They don't acknowledge that a hybrid pickup with an inverter generator (like the Ford PowerBoost with ProPower On Board), will do much better (possibly up to 700 mile range on a 31 gallon tank) because the Ford can share power generated by the ICE and/or regenerative braking with the LightShip.
Air Conditioning will be from a high voltage electric motor heat pump compressor found on hybrid and EV vehicles. The HVAC system is in the aerodynamic shroud over the hitch.
