John&Andrea
- Jan 28, 2021
- Dallas Georgia
- Coachmen
- Concord 300ts
- E450
- 7.3 Godzilla
- 2019 Ford Ranger
"If the problem only happens when in tow mode attached to the coach, then the coach flasher(s) may be the problem." THAT is the ONLY scenario in which that Rt turn signal on the towed vehicle doesn't flash. The MH flashers work fine when attached to the toad vehicle. So how can this be the coach's flasher malfunction?There is no ignorance here
Everyone cannot understand everything.
If the right light is not flashing when disconnected from the coach but in tow mode, the problem may be in the towed vehicle’s flasher or even the tow mode components.
You certainly have a puzzle.
We're going to remove the tail light assembly of the toad vehicle tomorrow to look at that wiring. I think we have a diode kit installed in there, from reading more about this. So, we'll see what we can see in there.The wiring system is plugged in. The coach is not physically attached to the tow vehicle. Try in tow mode and not in tow mode. I suspect there is a ground feeding back thru the hitch. Process of elimination.
Haha - we USED to have a Jeep Wrangler as the toad (but hated that jeep) and needed more room (the F150 is our "garage", since we're full-timers). I suspect we have a diode system. We're going to remove the toad's tail light assembly tomorrow as see if we can notice anything amiss.On My Jeep, I have a "non factory" wiring harness that connects to the Trailer Wiring Socket on the Coach. That harness runs underneath the Jeep to the FACTORY plug at the Left Tail Lamp. It does not use any diodes. All it powers is the Park Lamp circuit and the Left and Right Turn Signal circuits. The Brake and Four Ways use the same circuits. It is a very simple set up and does not use any OEM power from the Jeep.
It sounds like your set up uses some factory circuitry on your F150. If that's the case, I suspect you have a sophisticated Ford problem. Is it too late to buy a Jeep? Just kidding!!
Good luck and let us know how your problem was resolved.
Darrell
We do have a 7-pin and a 4-pin connector tester, but not a 6-pin tester. Need to get one, though. thanks
I'm not all that thrilled with the JK wrangler I have now. I call it a car in Jeep's clothing. I don't like plush carpet and a whole lot of electrical gadgets. I've had a CJ, XJ, TJ and now this. My absolute favorite was the TJ. It had 350,000 Kilometers on the clock and easily another 50,000 unregistered (towed). It first died on me about thirty miles west of Hawthorn Nevada on an old mining road. It did restart so we didn't have to walk back to civilization. It ended up needing a new crank position sensor. It was then deemed "no longer reliable" by my wife so it had to go. I still like the "go anywhere ya want" that the Jeep is famous for and it is so simple and easy to tow. I'm glad you like your F150 but it's too big for my liking. Different strokes.Haha - we USED to have a Jeep Wrangler as the toad (but hated that jeep) and needed more room (the F150 is our "garage", since we're full-timers). I suspect we have a diode system. We're going to remove the toad's tail light assembly tomorrow as see if we can notice anything amiss.
We'll test the 7-pin MH connector. Last time that was checked was about a month ago, and all the wiring at that end were "hot". But, we'll check again with the tester we have. thanksHave you put a test light the connector coming off the motor home to verify the turn signal if functioning at that point? next plug in harness from the truck and trace the right turn signal test is as well, next move towards the connection point to the actual truck harness and taillight assembly
From your picture of your connector, it appears you have:It was really corroded
I'm glad to see you added "apply solder to the ends of the wire". It is such an easy way to make sure there are no "stragglers ( threads of wire that don't go into the socket), less chance of corrosion and better contact with the socket.. I always apply contact grease as well. Good advice. thanks for sharing.From your picture of your connector, it appears you have:
Tail / marker lights
Brake / right turn
Brake / left turn
Ground
I am guessing your toad brakes are in the hitch.
Take a picture and/or make a diagram. Remove the wires. Cut your wires back to shiny copper, or clean them with fine sand paper or steel wool. Be careful not to get steel wool fragments in the contacts. Solder the ends of the wires and use electrical contact grease to install the wires back into the correct holes. Consider buying a better grade metal connector assembly from a trailer dealer. Wrap the wire assembly with good electrical tape, preferably 3M. Do not over wrap so the wires will not go back in the socket.
I suspect your poor contacts have made other contact areas to become compromised. Now you have a start and you did not pay Freightliner to search for the problem. You can use electrical contact grease on the light socket connections if you like.
Darrel, Thank you for the clarification to our members. I know what I meant and so did you. The procedure is tinning the ends of the wires. The little screws are easy to strip out. Be careful not to over tighten."apply solder to the ends of the wire"
