Question Rettroband - are they worth it?
Good news he was there to talk about it😎
So, what were their, or his if you only met one, impressions of how the Rettrobands did during the blowout?
Yep, I think it happened on the way to Hoots. My concerns remain but statistically (or publicly) we will never know. i.e. are installs contributing factors.
glad to hear you got it all worked out. You were a bit stressed out when the damage was first apparent.
Good to meet you! Enjoyed our chit chat.
Saw this on the Newmar Owners Facebook group
If you are insulating that watching your tire pressures, having a TPMS and taking care of your tires you can avoid any issues with tire blow outs, I respectively disagree. I baby my tires in so many ways but still almost had a disaster when a bubble formed on the inside of my tire. I found this after a trip coming out of the VA mountains. This could have been ugly and life threatening. I got luckily. I now have Rettrobands as that extra insurance.
Agreed. I've read of multiple blowouts described by RVers that say that had TPMS and had zero warning of heat or pressure prior to their blowout.
Can you post these descriptions, I don't see that many stories
If you search for blowout on here or IRV2, you will find multiple. Searched blowout here, and it was the third item on the list:
May have to check with Neil, site may be messed up, I got an email alert that you posted this (see below), but can't find it on here. Am confused by your response, so was going to ask for clarification and how that was the driver's fault or akin to running out of fuel.
team bradfield said:
So, that means no? I ran out of fuel once, tried blaming it on the fuel gauge, appears it was operator error
deleted
I had an interesting exchange with nirvc today about rettroband. I connected with Chuck Lasley at NIRVC and I didn’t know there’s a Rettroband weight limit on the front.
Your tires which are most likely Michelin’s are rated at 10,500lbs per tire if I am not mistaken. So we are really concerned with just the front end and weight of the front axle of the coach. RettroBands are engineered and tested to withstand a sudden release of air and weight drop of up to 30,000lbs.
Second, they recommend replacing the steers if they are close to four years or older as when they reinflate the tire it can “break” the bead.
FWIW.
FWIW.
And this would only be for new installs…
