Question Wheel levelers
gpz1100z1
What does everyone use for their dual axle wheel levelers? I've seen the stable crate style and the roll up rocker types.
What's a dual axle wheel leverler?
Are you asking for a tool to lift a heavy wheel onto an axle?
No. I have a dual axle rv. I've seen the type you roll up on and the plastic block plate style.
The question asked is:
Do you have tandem axles, or tag axle, or maybe dual wheels. We need an understanding of what you are trying to do.
Other things we might find helpful is the weight any block might need to support.
the type of what? What is your goal?
I give up. If you can't type more than 5 words to describe your situation, what you are trying to do, I don't have the time to force it out of you. You are trying to put blocks under your tandem wheels to level your RV? Ok, do that. Do you have a hydraulic leveling system? Is the RV on even ground?
Wow, I can't put it any simpler. I'm trying to just level the rv at the campsite. Don't reply then.
Ok, hit the button that says AutoLevel.
My grand design doesn't have auto leveling. These are two types of leveling systems I'm looking at.
Now we're getting somewhere. I have used the blocks. I have also used ramp type units. If you boondock on rough terrain the blocks will deform keeping them from stacking in the future. The ramps I have were purchased at harborfreighttools and are fair. They don't support the tire well so I feel less inclined to use them.
My goto are blocks I made alternating between 2×4s and plywood. After all it ain't rocket science.
I have both, blocks for flat/cement areas and the ramps used in conjunction with the blocks for rough/dirt/grass areas.
currently I am parked on grass/dirt, the ramps keep the trailer level and the blocks keep it stable and minimize the bounce when walking in the trailer (or when my dogs are bouncing around and jumping on and off the bed)
We have a Lippert Power up and Power down hydraulic leveling system and that is what we use. If during leveling the wheels are off the ground we have pieces of 2x12"s that we place under the wheels so they are not on the ground. There are a plethora of leveling blocks out there just make sure they can handle the weight of you rig and they are large enough to hold your tire sized
