Question Wheel levelers
gpz1100z1
What does everyone use for their dual axle wheel levelers? I've seen the stable crate style and the roll up rocker types.
What's a dual axle wheel leverler?
Are you asking for a tool to lift a heavy wheel onto an axle?
No. I have a dual axle rv. I've seen the type you roll up on and the plastic block plate style.
The question asked is:
Do you have tandem axles, or tag axle, or maybe dual wheels. We need an understanding of what you are trying to do.
Other things we might find helpful is the weight any block might need to support.
the type of what? What is your goal?
I give up. If you can't type more than 5 words to describe your situation, what you are trying to do, I don't have the time to force it out of you. You are trying to put blocks under your tandem wheels to level your RV? Ok, do that. Do you have a hydraulic leveling system? Is the RV on even ground?
Wow, I can't put it any simpler. I'm trying to just level the rv at the campsite. Don't reply then.
Ok, hit the button that says AutoLevel.
