Resolved System Control App
ARD
Moderator
Fulltiming
London Aire 4551
Yukon Denali
Hey London Aire peeps or anyone that has an idea-
For some reason, I can no longer connect to System Control using any of my devices. Wifi has not changed. Any ideas on how to troubleshoot? Thanks.
The device that system control connects to is very flaky. It has to be rebooted. The proper way to reboot is to disconnect it, wait a few, and reconnect.
The problem is the location, which is behind the display panel above driver. A bunch of screws to remove and wires to move around. Mine stopped working and I have not reset it for a while.
Might make sense to install a switch to cut the power where you can reach It.
On my 2020 Mountain Aire I added a switch in the electrical bay for the TM102w as that unit has 'its hands in all types of things". Generator, Inverter, relays, on and on... Power cycle it on average about 1x every 45 days when we are out.
Would a salesman switch off for 30 seconds work to reboot this?
UPDATE: I lost System Control because all the WiFi info on SL was gone. The module (LR-125) fell asleep. It should not fall asleep and will need to be updated per SL; however, to wake it up if this happens to anyone else, you would need to take the velcro panel behind the power reel out and go to the SL fuses noted by the green panel located at the bottom. Take out F1 and F2 and put back in. I'm good to go for now.
@ARD ... great information. My System Control app on my iPhone still works, however several control functions that used to work have stopped working like the shades, TV up/down etc. I will try the F1 and F2 deal and see if that fixes it. @redbaron initially helped me to get it installed and running.
FLSteve (y)
@SteveMA ... is the TM102w located in the electrical bay or is that just where you added the switch?
FLSteve :unsure:
Thanks Ard,that is great info to have…like with any computer,reboot and away you go….usually!!
FLSteve :unsure:
TM102 (2020 Mountain Aire - I think similar for all) is in the shore power bay behind the large plastic cover. It is in the lower right on mine. Over time I have found it is crucial to many SL systems including the communications with the generator and the Xantrex inverter/charger as the Xantrex 3012 does not network with RV-C and the TM102 is the 'translator'. There are several devices in our MA that are KIB "FET" "power controls" that are supposed to disconnect all power from the SL modules if your house batteries get below 10.7v ±. My batteries were run down to 6.2V when the coach was in for service and the KIB FET devices would not come back online. Unplugging them waiting 10 min and plugging them back in was the key to regaining SL functions. Sadly the 3012 failed. Ended up getting a new one from Inverter Service Co in White House, Tn and they also fixed the old one, so I am likely going to put both online when I change over to LiPoFe in the spring.
FLSteve (y)
FL Steve - The shades, TV etc on 2020 MA are controlled by KIB. I Had to go to the KIB "hub" box over the sinks in the rear bathroom, Open the metal box and pull power from the modules and then it all reset. Caution the "hub"box is a wiring embarrassment, looks like somebody hacked to together behind their barn. Just go slow. there is a 12V fuse for the KIB system (I think in the mid bathroom electrical cabinet) however it seems to be fed power several ways, so I ended up powering down the actual circuit boards to restore all. I am thinking about selling my business and retiring and then sitting down and making a system for RVs that is not such a kludge of bits and pieces. (We do major AV and network work for large industry and Gov) I can assure you we would not have been in business for 40 years if we had ever delivered projects like what I find in these coaches....
@SteveMA ... thanks for all the information. I will print it out and go to work on it tomorrow.
FLSteve :)
