Dometic hot water tank failure
Henry
Lance
2375 travel trailer
Hello, We have a model 2375, year 2021 unit. The WH-6EGA water heater has sprung a leak. Clearly appears to be at the resting point for the tank on a thin walled petition opening. This point of contact seems by design harmful to the aluminum tank.
Has anyone experienced this failure? We’ve put a lot of miles on our Lance in a couple years.
Thank you in advance.
Henry
Does the water heater ever get turned on with an empty tank? This is very tough on the device and it overheats.
Rick
Is the leak the holding tank itself or one of the crimped water lines?
I haven’t pulled the tank assembly out yet. New replacement will be here this Friday. We’re on the road so I’ll hold up pulling it until the replacement arrives. It clearly appears to be from the tank or possibly one of the welded tube connections to the outside panel face. It’s a pretty severe leak.
It’s a free standing tank. Seems like this allows for the tank to flex from road jounce on the tubing connections to the face panel. Just doesn’t appear to be a stable platform for the tank. I’ll be making a larger more stable platform to include a strap tie down system.
Thank you for the reply.
Henry
Rick
We purchased new so to my knowledge this hasn’t happened. Is this something that can result in a leak?
Henry
It is rare that a tank leaks. I have seen bad welds on a Suburban steel tank, and I would be more inclined to think you have a leak at the cold inlet or hot outlet. It is not where the tank rests on the support. The aluminum is thicker then that.
The tank s currently isolated and drained. Definitely taking a closer look at the inlet outlet connections today. I’ll post what happens after testing for leaks.
Thank you all for the help.
Henry
Henry
After refilling and pressurizing the system the hot /cold connections are completely dry. It s clearly evident the leaking at the tank resting point at tge petition cut out. Hard to see in my picture but up close its easy to see water bubbles out on the insulation.
Looks like you ordered one...I happen to have one that's almost brand new (owner replaced for "on demand" system). If you are near the Central Coast of California (long shot I know 😉) I would sell it to you for a very good price. Otherwise, best of travels friend. Blessings
Thank you for the offer sir. I found one on Amazon. Price was right for new. Much less than dealer near by. Dealer quote was over $1000. Three weeks to get it to Texas from them. Amazon delivery this Friday.
I hope this isn’t a regular replacement need. Very disappointed to only see two years service in this one. I’ll be looking at the passive system next time.
Thank you!
Henry
2 years on an aluminum tank? Something is wrong with that picture......Please show pics of the punctured tank.
I have had fittings loosen over time while driving. There are some screw fittings, have you verified the leak is not a fitting? Just a thought.
I’ll be pulling the old tank Friday when the new replacement arrives. Definitely will be providing pics.
All indications at this point is the tank leaking where it rests on a thin wall petition cut out. I’ll have a better look at that point when it’s removed. Pics I’ll share.
The new replacement Dometic hot water tank has been successfully installed. Working great!
This was clearly a tank stress crack as the pictures show. Note the rubbing scar caused by the narrow petition resting spot. I’ve added blocking to expand the resting surface and secured the tank with a nylon strap. Hoping not to have this issue again.
I’ve also reached out to my dealer. They’re submitting this for a warranty claim.
Henry
Glad you made a successful repair. You had the correct diagnosis.
Wow, that thing must have taken one hell of a wallop. Learn something new or see something new all the time.
This wasn’t a failure occurring from a one time, “wallop.” It’s been over time and many miles placed on our trailer. Since our purchase new, we’ve been traveling over many rough roads across the country. As I’ve mentioned, this was caused by design. Over time and mileage the failure is likely to occur. How many others have experienced this I ask??
Thank you for all replies.
Henry
Hello Henry - We have a 2021 Lance 2375 and have just experienced exactly what you went through. I haven't pulled the tank yet, but will soon. Just curious, were you ever able to get Lance/Dometic to reimburse you?
Steve
