Whirlpool Refer water issue
Texas Clodhopper
Garden Ridge, TX
Ventana 4369
Longer daily
Cummins
2025 Jeep Gladiator
I replaced the water filter and have problems getting water for the ice maker and the door water dispenser. I know it must be airbound and I've tried all the manual and online tricks to get the air out. I get either a trickle of water or no water. I've held the water dispenser down for 5 seconds off 5 seconds and repeated it multiple times. I've also held the water dispenser for 5 minutes. Any ideas from this vast unpaid wealth of knowledge?
For my house refer procedure after replacing a filter it's letting about 1-2 gals through. Have you tried holding the water option on for a longer time maybe a minute or two?
Have you tried removing and replacing the new filter? Inspect for clogs in the new filter? You know, obvious weird things?
I assume the water line in the basement is intact and shutoff valve is open?
Is water pump on?
I've tried for 5 minutes. A trickle will come out then nothing, trickle, nothing, on so on.
Yep, removed and reinstalled 3 or 4 times. I'm not sure how I would check for a clog in the filter.
I checked and yes, its open.
Is water pump on?
same res
The water pump was on and I connected to the park water with the same results.
Do you still have the old filter?
Well of course not!!!! That was the first thing I kicked myself in the rear for.
I've ordered another one from your store. I sure wish you shared your profits with some of us underlings.
I’ll get you a link to refurbished filters :) Save a few.
I would appreciate the link, thanks.
aka gently used...
Try taking out the filter and running the water without the filter installed for a few seconds and reinstalling the filter.
The filter must be installed.
A quick Google search says you can. Even if your manual says it can’t I would give it a try.
Thanks. I may have tried it with the door open and I know it won't dispense water with the door open.
I removed the filter and the water flowed freely. This was the 3rd filter I had tried.
I returned the last filter I bought to Lowes and was told they get returned regularly so I did some research. Apparently, a "bad batch" of these filters has been manufactured all with the same problem. At $40-50 a pop, I'll go filterless for a while.
some of these filters have a cap on the inside that needs to be removed before installation. they are usually clear so hard to tell they are there.
