- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
At Freightliner (FCCC) Gaffney, SC and like last year I asked them to do a leak check as I've been concerned about tank 2 not holding air and also seeing some lower than desired air pressure on tank 2 while driving, just above 100. As pointed out by @J&JD HWH Active Air can be a contributor to the air cycling and that is valid. However, it seems almost all of my air bags are leaking. Fronts are worse, rears are not that bad but in a year will probably need attention. I asked how long they typically last and he said 5-10 years, my chassis is 7 years old now. So as the theme of the year was spend as much as I can on the coach (new tires, RettroBands, LiFePO4 batteries and all new electrical system) so why not replace all air bags (6) for around $4500? Yep, let's do it! Ugh!!!
Moral is, ask for leak checks during your chassis annuals and be aware of dry rotting bags, lines, cracked fittings, etc. I want to enjoy my travels when going to destinations and not be dealing with issues so now is the time to get it taken care of.
