Fender completely ripped off
JeffAndPam
Alabama
Fleetwood
Flair, 34R
34'
One of our fenders completely ripped off. Would like to know a relatively easy approach to get this back on.
It's a 2005, so it doesn't need to be a polished solution.
You could try to glue or epoxy all the broken tabs back on and reinstall. Make sure you keep all in the same order
Question: I noticed my thread got moved to the "Fleetwood" forum.
I'm curious to know why. When my question seems unique to Fleetwood, I post it there.
But I feel like this is generic enough that I'd like to hear from a wider audience, not just Fleetwood owners.
Perhaps others have found a good way to get a fender back on, regardless of what type of RV it is.
Just curious really...
I think I would try to superglue it back on to the tabs. Just to make sure they are in the correct position. Then remove it all and work on it from the backside. Superglue by itself isn't that strong so you'd want to just loosen all the screws first. In any case one or two tabs might not stick. Put them back on later.
The real repair would be on the backside. Lately it's been a 50/50 shot whether epoxy works on such issues for me. Not real thrilled with that. I've been using superglue and graphite for some things. Superglue and baking soda for others. It's surprisingly strong and when you use the glue with various powders it basically sets instantly. Like we always wished superglue would. For more details and examples there are bunches of how-to videos on Youtube. One latest one I saw they were using it with cement. You can do some pretty slick repairs with it but each and every one tends to be pretty ugly. Hence doing the work on the back as much as possible.
That was good advice! Trying to line the broken pieces up after taking them off would be problematic.
I'll temporarily tape the whole fender on for placement, then superglue, then remove everything and work from the backside.
Thank you!
For some reason I can get the link to paste. But I have had a lot of luck with this product.
Super CA Glue (2 x 4.5 oz.) with Spray Adhesive Activator (2 x 16.9 fl oz.) Ca Glue with Activator for Wood, Plastic, Metal, Leather, Ceramic - Cyanoacrylate Glue for Crafting&Building (2 Pk) (amazon of course)​
Got be fast though.
So it's not a fender skirt right? When in place you won't care to take it off again, right?
That taken care of! I would follow the above advice but would finish the job off with UHB 3M double sided tape applied between the bolts.
Still waiting to hear how it happened in the first place? :)
So I had an issue similar to this with my motorhome rear cap. I made come small aluminum "U" clips that extended past both dies of the broken tab and fiberglass resin glued the clips and the broken tab together and then slipped them back on to the main part of the fender glue and riveted them in place and re mounted the fender then overlaid with fiberglass cloth and painted. Pictures show the result. There was much more to this project as I actually pulled the entire endcap off the RV. The top corner shown in the picture was torn off and I reattached glassed and painted. AS you can see I pulled every screw through the glass so it was quite a project.
You could:
Measure the arc of the old fender when properly applied to the RV.
Put the old fender ontop of some FRP that can be purchased from HomeDepot (panelling department) and recreate the arc dimension. Draw the inside line to what will be touching the RV panel (the white area). Cut the outline out with a right angle grinder. Cut on the line so it's slightly smaller than the fender.
Use the grinder and rough up the side facing the fender. Use "DuraGlass" and "glue" the FRP to the backside of the fender ensuring the Arc is same as measured. Glue on old tabs, matched to the fender breaks before the DuraGlass cures. DuraGlass is like body plastic, but with some fiberglass in it for super strength.
When dry, drill the tab holes through the FRP.
Reapply to the RV with the original screws. Other than it will be slightly proud of the RV side, it will look like new and will be stronger than original.
This is a 3 hour fix.
A simpler fix, if you don't care that the fender flare is removable, crazy glue the tabs to their position on the fender, rough up the white area with a flap wheel on the right angle grinder, and just Duraglass the old broken flare right to it. Lightly put the screws into the brackets until all is cured.
This is a 1 hour fix.
Me too! Previous owner briefly told us it came off and they stuck it in one of the bins.
Very good details. Thanks for the thorough response.
Your mention of "DuraGlass" (had to look it up) makes me want to add another question to this:
I have a hole on the side of the RV that needs patching. (I have so many questions about this RV, I'm having to trickle them on here). It's about 3" by over a foot in size.
So when I go to tackle that project, I'll need to purchase some product. Would "DuraGlass" be useful for that project also?
Take a picture of the damage
