Did we get a lemon?
Gambino
Hello, I am asking for help. We just bought a new 2023 Tiffin Phaeton 36SH. When we went to look at the RV the passenger side rear slide would not fully extend due to a broken hydraulic hose. The dealer said they fixed it when they dropped it off at our house but we do not think the slide is fully extending.
If somebody could measure the outside of the rear slide when extended, we would be very thankful. Also, we see cables in our main storage bay. We are not sure if this is common or if the service department did not put panels back to seal the wiring. Could you take pictures of the roof of the main storage bay that has the slide out storage. Do you see cables or are the cables completely enclosed.
We would greatly appreciate your assistance. Thank you in advance.
Sorry but if you think those couple small issues makes you feel like you might have a lemon then you are in for one heck of a disappointing RV experience. You should understand that “things” happen with these things pretty regularly. It’s an unfortunate part of the ownership experience.
As far as the hanging cables go, grab some zip ties and bundle them up.
As far as the slide goes, check the seal behind the trim on the inside when the slide is open. It should be tight against the interior wall. If not, it is not open all the way and there may be something hidden that it stopping it
Best of luck!
I am attaching two pictures to show what I am describing.
Let me provide a more optimistic approach. All RV's come off the line with problems. There is a warranty period and you should take notes and schedule your services to get warranty items cleaned up. I did two visits my first year and had pages, and then things after that and typically an annual visit for cleanup. It's normal. You will find things now and tomorrow. Document them and arrange to have them fixed.
Wow. If those are the only two issues you have Congratulations. You will have more. Best advice for slide is measure both ends outside when extended to see if they come out same distance. Also check inside both ends to see if it is fully extended. Two possibilities bad motor or slide not synced.
Some advice if you want…use the coach , use the coach, use the coach for at least three months. Write down the list of repairs needed. Bring back to the dealer and WAIT. Could be three or four months before you get your coach back.
Hi and Welcome to RVforums and the RV life. As others have mentioned these type of issues are to be expected. The slide extension, check on the inside wall and see if the slide it tight to the wall if so, it is fully extended if not you have an adjustment issue.
Remember this is a house on wheels with more systems then your brick and mortar. Things will rattle loose and need attention. Enjoy the Journey! Above all keep your sense of humor. It will make these headaches easier to handle.
Welcome.
I would not worry about measuring the outside. Go inside and where the slide out meets the wall to see if there is a gap. Now the trip will not hit the wall, but behind it is a seal that will. If it touch’s your fine.
For the storage area if you see holes around the edges of the storage area to attach a panel, they may have missed it, but holes could be there for other reasons too.
As I've frequently written and said: "New only guarantees new, but not necessarily good". With any new RV, one should expect to find things that need adjusting, repairing, and/or replacing. Just the nature of almost all RV products, be they a motorhome, 5th wheel, travel trailer, etc.
Do make a written list of your concerns after you have the opportunity to use the motorhome on a couple of trips. Then schedule an appointment with your dealer and provide them a copy of your list. That will minimize the "he said she said" issue or "you never told me about that". Then once it is ready, it is up to you to confirm all the issues on the list were resolved. Just remember, regardless of the price, it isn't going to be perfect.
It will take some time to resolve all the issues. Be patient, enjoy your wine. It is only RV life.
Bob
Owning an RV means you have to know how to also fix things yourself! You won't always be in a spot where you can wait for a service visit; lots of online How To videos, and this forum, are always helpful!
Yep, very true. Just making the payments is a small part of the responsible RV owner's job.
The slides don't all come out the same distance. And the slides with utilities need slack so they can operate without ripping something apart.
I think you'll find your slides is out all the way.
Mark
Your cabling looks fine to me from your pictures, like I said the wires and such need to be long enough to reach when the slides are out, so there's bound to be some slack. Like was mentioned before, check that slide on the inside, my money is it's a shallow slide. 👍
I just looked at your floor plan, the bed slide and dresser slide are both shallow, the dresser/TV slide looks to be shallowest.
