Tires. 7 year rule?
Tjdave
motorized toy collector
Wa State
Tiffin
Allegro 32sa
F53
V10
2018 Jeep Wrangler Unlimited Rubicon
I believe. Do you? I just ordered 6 new Toyos to replace the original Michelins with a 2017 date stamp. They still look great, but the piece of mind was worth it IMO. Not full timing yet and it sits alot. I saved $1K by going with Toyos. I hope I'm not disappointed.
Heard a lot of good about Toyos.
After what I learned I would go Toyo's over Michelin. I lost faith in Michelin. I think Toyo's are a more durable "heavier duty" tire. For those stuck with Michelin for fronts I'd go Toyo's on all others in that scenario.
I have Toyo’s as well. They seem to be working well. The tire guy that I used told me that Toyo’s hold up better than Michelin’s against UV damage. The tire compound used for Michelin’s is very good for tire wear and performance, but breaks down a little quicker than Toyo’s and other brands.
He said his recommendation would be to change out Michelin’s every 5 years where Toyo’s could last up to 8 yrs.
I respectfully disagree. Been a Michelin customer for 30+ years. Never a problem. On the motorhome I have always gone with the 7 year rule even though the Michelin’s have always looked great when changed out. Some trucker probably got a lot of mileage out of my old tires.
It's all in the compound!!! This is industry knowledge! I'm not knocking either,as both are great tires. That said,toyos handle uv better, but don't provide the same ride, or traction.
If you need more years toyo wins! If you're like @Neal it's a toss up! If you're a commercial driver Michelin wins.
That’s fine. I really don’t know either way. I’m just referencing what the tire shop owner said. It’s all perspective I guess.
Plus he is in the commercial world as well. In the RV arena we don’t abuse our tires as much, keep them clean, put tire dressing on them, cover them up when sitting for a long time undoubtedly helps the tire.
Curiosity! How do you handle the inside tire wall? You know the pressure side! Also, how do you deal with the tread side? Also the wall you aren't looking at.
Friction within the tires produce ozone (what causes tire checking).
So how do RV owners really care for their tires??? Best solution is to buy tires that are designed to give what you are looking for!!!
Good points..
In the cleaning and protecting I was focused on UV and not Ozone.
I guess the only thing you can do about ozone is to try and reduce friction and that would be to maintain proper tire pressure. I’m not sure what you meant “(what causes tire checking)”?
Good points..
Sorry (that)
Nitrogen fill eliminates oxygen, therefore no ozone inside the tires. Costco will fill for you!
This is only a help, not a cure. Pressure helps distribute ozone inside the structure of the tires.
That is what is particularly bad for Michelins especially. They last much longer when kept rolling. They develop sidewall cracks when sitting for long periods, even when covered. My first set on prev MH only lasted four years.
Btw, so far the Michelins on the current coach still look good after four years. Will likely replace them in 1.5 to 2 years..; likely with Michelins, but who knows. Traction is very important to me , as I have had to lock the brakes for brake checks and deer avoidance. The deer was suicidal because he looked out and saw me coming, yet ran out anyhow. To his or her credit though, maybe the little car next to me was hidden from view. That is who actually hit the deer. Totaled it.
I had Michelin and switched to Toyo for financial reasons. I had a Ford and switched to a GMC because I wanted to.
Question: Does Nitrogen in the tires not expand & contract with temperature changes?
If so, it certainly would help in maintaining the correct tire pressure.
Yes, or No??
Yes, or No??
Less expansion!
