Overhead Front Amber Clearance Lights
Texas Clodhopper
Garden Ridge, TX
Ventana 4369
Longer daily
Cummins
2025 Jeep Gladiator
I need to replace 2 of the front overhead amber clearance lights on my 2017 Ventana. I checked Newgle and only the side marker lights are listed and for once I remembered to do a forum search with no luck. I know there is most likely a DOT number on the fixture but I'm trying to save a trip on the roof of the coach. Any suggestions?
Like
Comment
Send
Get spare overhead front/rear lights, side orange marker lights, and the license plate light. Email Newmar Parts, Joe Gentry is who gives me the great info. I've had two state inspections now where one of these dang lights were out as I didn't check. For those at Newmar doing the o'dark'30 wake-ups, this is a great time to check your lights as the tech pulls away with your coach.
[email protected]
PN 119735 - $5.90 each. IN STOCK – Amber
PN 119736 - $5.90 each. IN STOCK – Red
PN 129114 - $1.90 each. IN STOCK
Thanks, Neil. I was going for a state inspection but checked my lights first, for once.
Email sent including spares.
I just replaced two up front…. They don’t always give much spare wire, so I used small vice grips to hold them in place. And only cut one wire at a time. :-)
I just replaced two up front…. They don’t always give much spare wire, so I used small vice grips to hold them in place. And only cut one wire at a time. :)
Thanks for the heads up. Are they screwed or just used the caulk.
Any auto parts store, NAPA, Auto Zone, OReilly carries them. The ones Newmar uses tend to burn out quickly. I have replace all of mine with a little better quality LED ones from OReilly's here is the link
I will second that on the short cables. Could not get one of them out more than ~¾" and had to splice on. used locking forceps to hold the wire. You would think if Newmar could just move some of the 100's of feet of spare wires all over the coach to just a few more inches on each of these marker lights in a totally unreachable location on...
These don't look anything like mine, but thanks.
They are just caulked….but they are snuggly stuffed in each hole. You will need some good caulk. They used clear caulk on mine (a lot) but I recaulked mine with black to match my rig.
The wires are longer than you think. The wires are bound up in the goop they put behind them to keep moisture out. There are actually bullet connectors back in there somewhere. My coach is five and a half years old and I replaced all five. I am not sure, but I think the best way to get them out would be to drill a small hole in the center and use a slide hammer to get them out. I came up that that idea after I had to take the cabinetry out to get the last finished. They all had to be pried and chiseled out. They are 3/4" button lights that are available as said above at auto parts or truck part stores. I got the ones with chrome bezels.
I agree about the bullet connectors, but I could not pull my wires out far enough to reach them…and I didn’t want to pull too hard and have the connectors let go and fall into the void…
I'm starting to dread changing them out.
LOL. I did too…I put it off for almost a year, but in the end, it was not that bad. You can use Wago wire clips…. Just tape the tabs closed.
It really is to bad that they don't use the guidelines for wires in a J-box(6").
Except it would be really hard to put a j box behind these lights…. I would be happy to have been able to reach the bullet jacks.
