What’s the digital gauge
Ghubb
what’s the little digital gauge lighting up on a by cruiser. Can’t find it in the owner’s manual. Thanks
Well I’ll take a guess 😊
Looks like it was added after based on the wire coming out of the dash and appears to be stuck in the dash.
From the indicators on each side I’d guess it is something to let you know when you are getting outside your lane in the road.
Or maybe a level indicator letting you know what to do with jacks.
Tried the image search on the web but couldn’t find one that matched in the results.
Maybe some type of aftermarket back-up alarm? Were you in reverse when the pic was taken? (The lit green arrow.) Might there be some sensors on the rear bumper?
Roger
radar detector?
It definitely has an alarm to it because it’s in a steady tone now. No jacks so it’s not that. I didn’t find anything on image search either.
I’m leaning toward something electrical because it goes of when I pull my lights on. Thanks
radar detector?
No, but it is an alarm that f some sort because it is a steady tone.
Leaning towards electric of some sort because it goes off when I pull light switch on.
Gonna look at battery strength next. Alternators working but maybe battery is going dead.
New insight here! Have you checked your lights for a burned out bulb?
Clearly aftermarket add on. Have you looked for a Bluetooth signal? Possibly some type of weight or level system or tire pressure alarm.
Trailer sensor?
Of course none of this makes sense with lights turning off signals.
Just figured It out!!!
I hear lights are required in Canada. Don't know if that's true, but sounds right to me!!!
So you are looking at a reminder to turn lights on, something needed for someone planning a trip into Canada from the US where it is not mandated!!!
The "L" is the tell tail!!!
Very good possibility. Pull that panel and follow the wires and you’ll know for sure.
View attachment 24013what’s the little digital gauge lighting up on a by cruiser. Can’t find it in the owner’s manual. Thanks
Can you find a company name and or part number on it? May help to figure out what it is. Info may be on the back side.
