- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I've been very fortunate unlike other stories with the LED ceiling lights in my 2017 Newmar Ventana. But I had one start flickering underneath the master bathroom cabinet so it was time to replace. Newmar parts doesn't sell the ones for my coach anymore, the cover for it is not the same type, it's more white vs. translucent in mine. I found them on Amazon and it's an exact match, I replaced my bad one. Great tip from @Stuart S which was to clip the wires closest to the failed assembly to keep your wire runs the longest as there is no simple unplug and plug but you have to cut wires and use wire crimps to wire connect in the new lamp. For those with the translucent LED lights, here is the link to what I found:
TIP: when you cut a pair of wires such as these 12V wires cut each wire individually. I was brilliant one time cutting both at the same time, yep, shorted the connection as the cutters bridged the two wires and blew a fuse. Learn from Darwin!
https://www.amazon.com/gp/product/B06XR85Y7B/?tag=rvf01-20
