Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
Is your OASIS AC I/II on? That alone is 22+ amps.I’ve noticed that even with minimal utilities running, one ac unit and cooktop, we are pulling 50+ amps??
With the dryer running the pull exceeds 60 at times. Have yet to pop a breaker. ???
You are drawing way too much power. Actually I am more concerned that your main breakers are not tripping. In my rig I can run both AC units and other appliances without tripping. My AC units each draw 13 amps each. This leaves 24 amps available for other items if you loaded to 100% of available power. While circuit breakers are built and tested to run at 100% of their rating they are listed to be applied at 80% of the handle rating. if you apply that rule that available current on a 50 amp service is 40 amps which in my case in practical applications leaves 14 available amps after you take away the 26 amps used by ACs when running.I’ve noticed that even with minimal utilities running, one ac unit and cooktop, we are pulling 50+ amps??
