Question How many amps does your DP PULL
Joe Dutchstar
Florida
Dutch Star 4311
Cummins
2018 Ford Flex
I’ve noticed that even with minimal utilities running, one ac unit and cooktop, we are pulling 50+ amps??
With the dryer running the pull exceeds 60 at times. Have yet to pop a breaker. ???
I am no electrical expert but that would be exceedingly high in my book for just that few but you also have oasis and refrigerator and other stuff drawing power but that should be minimal. Where and how are you reading it?
Autoformer app.
Noted that front ac is pulling way too much as best as I can tell. That along with unknown issues with Autoformer life is getting challenging.
Without front ac draws look more normal
Maybe a bad motor in front ac…??
I would ask newmar for an explanation when you get to the rally. That much draw off one a/c seems off.
You would hear it. I had a bad motor on the front and it was loud like a grinder. Definitely one of the things they should look at.
No excess noise but looks like it pulls 25-30 amps continuously. Way too much.
The Autoformer is probably trying to sort out the difference in load between line 1and 2 which is substantial at times. Front ac on line 1.
My A/C's pull between 14-16 amps (each) once running...how does your front A/C match up against the others ? That would indicate a problem IMHO. Blessings
I suggest shutting down everything, getting a reading! Then one utility at a time get a reading so you can find the source of draw!
If power is being used when you think nothing is on be sure that the converter is off! That is not a small load when charging a large battery bank!
There is a strong possibility the circuits are not balanced very well because 220 is not always available. But then I don't know the wiring scheme.
Is your OASIS AC I/II on? That alone is 22+ amps.
I agree… shut things down and get down to close to zero amps and then turn things back on one at a time.
IMG_1721.pngOnce the load is balanced between line 1 and 2 things seem to settle fown
Had no idea the the Oasis drew 22 amps.
You are drawing way too much power. Actually I am more concerned that your main breakers are not tripping. In my rig I can run both AC units and other appliances without tripping. My AC units each draw 13 amps each. This leaves 24 amps available for other items if you loaded to 100% of available power. While circuit breakers are built and tested to run at 100% of their rating they are listed to be applied at 80% of the handle rating. if you apply that rule that available current on a 50 amp service is 40 amps which in my case in practical applications leaves 14 available amps after you take away the 26 amps used by ACs when running.
