Code readers
This is who I called on Labor day when I derated in Breckenridge, and they helped me even on the holiday.
You wouldn't happen to know where this DEF tank heater is located would you?
The valve in question is right on top of the DEF header on the top of the tank with a two wire plug going to it (red and blue IIRC). You can unplug it and test the ohms across the valve terminals - should be around 12 ohms and if its bad it will be a lot more (thousands) so its easy to check. The valve has a heater hose attached to it and the return line comes out of the DEF header adjacent to the valve. Its obvious once you know what you are looking for. I would guess 5/8 or 3/4” hose. The two protected small lines are DEF supply and return.
Caveat: I’m assuming since your coach is a 2016 that the chassis was built in 2015 and thus to pre-2016 emission specs. Everything changed for 2016 and later emission systems. This makes a difference in several key areas, the tank heater valve being one of them.
My chassis was built in May of 2015 and the coach was built between Dec 15 and Feb 2016 making it a 2016 with 2015 emissions.
They helped me on Christmas Day 2021 when I had a DEF pump failure. The trip was ruined but it was nice talking to a qualified person when stranded in a church parking lot on Christmas day
Dang Rich…you got that DEF thing down. If I run into problems…hope I can call on you. :)
I have a 2016 built in 2015 as well…. Guess at some point I need to school myself better on the DEF System.
Got my Diesel Handheld equipment in the mail today. Great deal on used unit-looks new with case and cords. Now to figure out how to use it. Checking Youtube. Any suggestions?
Check vendors website and also YouTube as you mentioned. Then, just plug it in and experiment. Learn now so you know when/if it's needed.
Anyone ever try this?
Thanks
Thanks
Interesting idea.
We have one of the plugin modules to tell the system all is well if needed. May have to track down the speed sensor just in case.
If I have the Diesel Laptop hand held do I need a DEF simulator seeing as I can do a manual regen and reset?
Thanks
I’ve read about people who tried this a few years ago and it does not work on an auto trans. Well it will prevent the ECM from reading speed, but it will also prevent your transmission from going into gear.
This is apples and oranges as follows:
The DSS will over-ride errant codes from the DEF header. The HD Handheld will clear codes but only if the issue has been resolved. But with the DSS installed the HD Handheld will clear the codes because DSS will make the ECM think the issue is resolved.
Regens occur in the DPF and DEF is injected into the SCR. Since the SCR is AFTER the DPF, regens have no affect on the DEF system. Regens will not resolve a DEF problem but will keep the DPF healthy and happy - a very good idea.
So the short answer is yes - they make a very good pair to keep you on the road.
Minor correction. When the DEF header fails no DEF data is being sent to the ECM. The DEF simulator (DSS) sends simulated data to the ECM which is similar to the data that the DEF header was sending, thus the ECM is happy and the codes will clear by them self after a few engine cycles.
OK - same thing I guess in my book. I was in on the beginning of the development of the DSS (at that other place) so I have a working knowledge of it, but at this point I tend to respond in generalities.
But the problems with a bad DEF header can be sending errant info such as an empty tank when it’s not, tank heat above or below normal ranges when it’s in range, or quality above or below, etc. - all that CANbus stuff that is beyond me, but allowed the development and implementation of the DSS.
There are also some negatives about the DSS and you can still end up with the same or similar codes a bad DEF header will cause but from other sources leading to misdiagnosis. But the bottom line is it keeps the ECM happy IF the problem is with one or more of the three sensors on the DEF header.
How can I tell which mfg DEF pump is on my rig? Freightliner 360 -6.7 Cummins built Dec 2018
