- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Ahh, got it!This is Freightliner Custom Chassis => RV's
FCCC is Gaffney, SC
The valve in question is right on top of the DEF header on the top of the tank with a two wire plug going to it (red and blue IIRC). You can unplug it and test the ohms across the valve terminals - should be around 12 ohms and if its bad it will be a lot more (thousands) so its easy to check. The valve has a heater hose attached to it and the return line comes out of the DEF header adjacent to the valve. Its obvious once you know what you are looking for. I would guess 5/8 or 3/4” hose. The two protected small lines are DEF supply and return.You wouldn't happen to know where this DEF tank heater is located would you?
They helped me on Christmas Day 2021 when I had a DEF pump failure. The trip was ruined but it was nice talking to a qualified person when stranded in a church parking lot on Christmas dayThis is who I called on Labor day when I derated in Breckenridge, and they helped me even on the holiday.
Anyone ever try this?
Thanks
Thanks
This is apples and oranges as follows:If I have the Diesel Laptop hand held do I need a DEF simulator seeing as I can do a manual regen and reset?
Minor correction. When the DEF header fails no DEF data is being sent to the ECM. The DEF simulator (DSS) sends simulated data to the ECM which is similar to the data that the DEF header was sending, thus the ECM is happy and the codes will clear by them self after a few engine cycles.The DSS will over-ride errant codes from the DEF header.
OK - same thing I guess in my book. I was in on the beginning of the development of the DSS (at that other place) so I have a working knowledge of it, but at this point I tend to respond in generalities.Minor correction. When the DEF header fails no DEF data is being sent to the ECM. The DEF simulator (DSS) sends simulated data to the ECM which is similar to the data that the DEF header was sending, thus the ECM is happy and the codes will clear by them self after a few engine cycles.
