Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
first, thank you so much. next, I did have "equalized" to, essentially "not"...meaning set as you indicate.nsr,
I have read the entire post and there is alot of good info. I run an MS2812 and 3 206Ah SOK batteries. It was Rob that said that settings could vary and not be wrong. With that said here is how my inverter settings go.
CUSTOM
Absorb 14.6
Float 13.8
Equalize 14.5
final stage silent
rebulk 12.8
LBCO 10.8
float time 30 minutes per 100Ah
I know there will be some screaming and gnashing of teeth on a couple of those settings, but it has been working well since January. I derived those numbers off of recommendations on this forum and the SOK forums.
There was a post on the SOK forums from Min Wang. He is an owner or engineer for SOK. He answers most of the tech questions presented. He had a post on there at one time that batteries would go to 13.0 to 13,1 and stay there for a good time while in use. That has been my experience as well. There is a youtube video from a gentleman that full time with a MS2812 and I believe battle born batteries. Very informative. You might go try and find it.
Yes! The pictures aren't obvious!hello Kevin,
forgive what probably should be obvious to you, but when you say "complete", you mean you want a diagram of what goes to "where", right?
I would also like to know the ground to frame information.Yes! The pictures aren't obvious!
If you want, looking at the drawing from bottom right=1 and top right=4 . Tell me what batteries are hooked up to the buss bars. Include the polarity!
certainly. i did include, I think, two photos of the ground but in the process of getting this done, I will make sure that we include it.I would also like to know the ground to frame information.
got it all. the ground was there when the factory first produced this trailer, which included 3 asto panels, a midnite solar controller and the ground wire you saw. when we changed to what we understood to be a "drop in" replacement, we simply left it there, used it again the way it had been previously,..but changed all the battery to battery wires and those off of the array, as well.View attachment 25279
What you want! (In above Pic)
The picture isn't clear that is what you have!
You showed the ground lug, but explain your reasoning for it!
My preference!(in above Pic)
The cable size is not going to be the problem under low load! So for trouble shooting don't change that. If you want to upgrade later that's fine
On the first diagram, I can't tell if your power is being drawn from (cables from one battery)one battery,or each end of the bank!
Because that issue is significant clarify that for me!
ps that ground was, indeed there from day one, in a system which used a magnum 2812, and the non lithium batteries always performed flawlessly, with none of these issues, so I am trying to simply understand, without asking you to make comments you are not comforable making at this point, what it is about this present problem that makes the ground suspect now but never before...and I trust/hope you will forgive me for belaboring this a bit?first, thank you.
I am not sure I am surprised, and I am impressed by your suggestion...have genuinely felt since day one here that you had your arms around this.
I hope, however, you will still permit me to ask the following (my perspective includes that I am a longtime amateur radio opererator who is going to use some of this solar power to run what is called "emcom", an acronym for "emergency communications", which I am interested in to help people in emergencises, such as hurricanes).......and I have for many years, always understood the need...in many areas, never mind that I am no expert in this area as you obviously are............... for grounds for performance, and/or safety). That said, then, and if I may:
1. where would you make the disconnection? right at the frame, itself?
2. would you have made this same suggestion if these were not lithiums but rather the original AGMs?
3. do you think the ground was a bad idea to begin with (I am wondering why the factory put it there in the first place)
4. am I the first case where you concluded that the ground was a possible or actual issue (due to the above, I am well aware that, generally speaking, grounds can also be sources of trouble as well as wellsprings of performance and safety, so I am not suggesting you have not discovered fire on this one)
5. is the suggestion related only to magnum or do you see issues with other equipment performing the same function, such as midnite or victron, just to name a few (to wit, I am about to finish creating that seond unconnected system I mentioned, and there are plenty of places to ground equipment with instructions to do so..such as with midnite's combiner box, through which on this SECOND system i keep mentioning I am, indeed, using their combiner box which will also go to chassis ground, albeit in the trailer rear, where I had a ground busbar type strip put into the trailer at the time it was made, albeit for radio purposes (without proper grounding of various kinds of equipment, one of the issues can definitely be heavy radio frequency interference with receivers and transmitters.
6. because "grounds" in so many areas, can be related to safety or performance or both, even as you are reluctant to discuss your logic, would you consider giving me at least a most basic, general idea as to why you have come to this conclusion?
you asked me about this ground previously, so it does not surprise me that you find that an area of interest.
and again, thank you so very much!
pps..sorry for stutter stepping, but I do have a clamp meter, just fyi......a kleintool and a fluke, both..although I am not unwilling to disconnect to see, either.ps that ground was, indeed there from day one, in a system which used a magnum 2812, and the non lithium batteries always performed flawlessly, with none of these issues, so I am trying to simply understand, without asking you to make comments you are not comforable making at this point, what it is about this present problem that makes the ground suspect now but never before...and I trust/hope you will forgive me for belaboring this a bit?
