Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
I see a possibility for a feed back loop at the transfer switch, the AC side to the DC side. Some inverters have an issue with such a feedback while others don't.
BUT!
At this time it's a trouble shooting effort. If you want to shield the inverter,then use the ground lug on the inverter. Grounding is an art that sometimes even professionals in lightning protection get wrong. I am of the school that believes in letting it float!
As for RF issues a good ground plain is paramount, so using the AC grounding system is important.
I try to listen well, but sometimes I get it wrong! This is a trailer right?
So the ground to frame is for the trailer brakes. A dedicated battery is in order. However we should be talking two independent systems. I would keep that in mind, when disconnecting the grounding cable.
As far as where to disconnect the cable? That will depend on if this corrects the issue.
Battery chemistry is irrelivent!
BUT!
