Need new AC?
Richpatty
Wesley Chapel, NC
Ventana 4310
400hp
2007 CR-V
It seems our #2 unit (of three) is not working…. It runs and even pulls the usual 13-14 amps…but never cools or warms up. Fan blows normally…and it seems like the compressor is running (amp draw kind of proves that). Not sure where to start. I guess it just lost its Freon…but not enough to shut the compressor down. I am told you cannot charge these units, so a replacement may be in order.
Thoughts?
Thanks
Rich
It can be charged but you need a willing HVAC guy to solder in the ports and charge it, find out why it leaked down, and fix that. And the ones I’ve found willing (very few and far between) won’t warranty their work on these things. The alternative is a new $1800 unit so it’s probably worth a try if you can find someone. I had National in Shipshewana install a new one and kept the old one to tinker with (still haven’t touched it) because I was on the road and wanted a one-time, reliable repair.
Thanks. I agree with your assessment…. Finding a person to try to charge it may be challenging.
I don’t think it is simple like a capacitor as I think the compressor would not run if that had failed…
I tried replacing the capacitors first because I couldn’t hear the compressor running but the tech at National said it was running, just lost its charge. Thats why I kept the thing - good for parts at least and maybe someday I’ll talk my brother in law, nephew, or son (all three qualified) into experimenting with it. So far they haven’t shown much interest.
I'm thankful mine lasted this long, I attribute it to using soft starts. I did not expect to get 7 years out of them, hope they keep going but it's in the mental budget of it's okay if they fail now, I got more time than expected out of them. Even in storage I do run them as I learned from my dash air failure that everything needs to be moving, cycling, etc. on an interval.
We had a unit go out in the same manner, running with normal draw, but no cooling.
Since ours was 10 years old we just replaced it.
Not a fan of this mentality to replace instead of fixing it. Such a waste.
Old unit was A/c only. Replaced with a a/c & heat pump unit to give us more options for heating, since it was virtually the same price as the a/c only unit.
We have 2 more units on the roof that we are waiting to see how much more time we get from them.
Ironically, and more likely coincidentally, our #1 and #3 units have soft starts…
You don’t really need to solder ports in. They have the puncture type now.
As Neal mentioned earlier, I believe using them helps with longevity. I know my #1 and #3 get the most use. I try to run #2 when I think about it.
And for finding and plugging the leak?
During the Hoots Rally last week, several comments were directed to Casy regarding troubles with the dash air. The statement that stuck with me was the $6000 NIRV estimate to fix. I don't recall how many owners were having problems but it was several.
I finally located my freon leak at the compressor— Ca-cheng, ca-cheng. I will deal with this when I get home.
If your replacing with new,,,the job is easy.Just getting up there that you need young strong man..and some type of lift.
I agree….but I have neither…
No fear!
You can bring the unit onto the roof sliding it up a extension ladder. Same to get the old one down.
Cardboard works to slide them into location.
As far as strong goes, your next door neighbors 100 lbs wife could easily do it.
No fear!
I appreciate the vote of confidence, but I literally have no one to help me. They are nearly 100lbs and wouldn’t want to risk hurting myself or someone else.
Update: After reaching out to Todd (manager at Atlanta) I was able to get a quote. They want $1861 for the AC unit, plus another $60 for gaskets and 2.5 hours of labor.
I guess its the price of owning these beasts...
Rich
