Engine Brake in Traffic
ARD
Moderator
Fulltiming
London Aire 4551
Yukon Denali
Well, I learned something new yesterday as I traveled I-40 in the blistering heat of Tennessee in terrible traffic. Do not use your air brakes as it will heat the tires up fast. Turn your engine brake on high. Yes, that is what Spartan told me as I panicked when my drive axle and tag tire temps creeped up to 190. Sure enough, once I turned the engine brakes on my tires started to cool. Of course, I sat on the side on the road for a little while debating whether I should let some air out of the tires. I did on one tire to no effect.
I hope this information helps someone that is not "in the know," like me. Oh, the tech also said don't confuse the above scenario with driving around town as you do need to use air brakes to deglaze the rotors.
Happy and Safe Travels.
I have never been in that kind of traffic with the RV. I think I would start reconsidering life decisions if I was :)
Yes, I don't recommend it. 😂
The only time I have ever turned my engine brake off is when it's raining.
You are fortunate. I encounter this somewhere on the interstates on almost every long trip, especially coming home. Although, I have discovered a MH friendly back road way in, for future reference. 😎
You haven’t experienced the thrill of excitement until your toad tire starts deflating in a LA traffic jam at 4:30 pm on the freeway and the shoulder is closed.
Tired Tv Land GIF by TV Land Classic
All I can add is your engine brake is your friend in 99% of driving. Mine is almost never off.
Love the one in our Superstar.
Coming over the Blue Ridge on route 26 I even had to hit the suggestion pedal a couple times due to the engine brake slowing me down too much 😊
Really like it in traffic too with people cutting in etc.
I never shut my engine brake off, even in rain. Coach is heavy enough that it will not cause any slide, and I don't drive mine in the snow or freezing weather....so far
I run with my engine brake off. My "three stage engagement switch" is on the right side of the column and very easy to turn on when needed.
Mine is off until needed
I recently posted about the DPF recharge overheating the drive tires. Spartan and the Dealer claimed this is “Normal”. And this was also on a 100+F day on I-40. No traffic but I slowed to 55 mph and once recharge finished tires cooled down.
Yep I did that to. I was in the Rockies traveling into Colorado Springs in stop and go traffic. I was so enamored with the scenery and the setting I had my engine brake off. It was 105+ degrees, pulling my tow and the temperature of my inner duals was over 200. Fortunately I was very close to the camp grounds.
Just to be safe I took my coach to a Freight liner dealer the next morning to have it checked out and it was fine. His advice was leave your damn engine brake on.
HH
Thanks for posting this information. Always good to learn from what others are doing. I have normally left mine off unless needed which is usually when driving in the mountains.
FLSteve :unsure:
