Russellvh
- Nov 18, 2021
- Home based out of the Colony, Texas
- Forest River
- Wildcat Fifth-wheel
- 2019 Ford F-250.
- Yes
I ordered one the day before yesterday.For Christmas I received a suction cup flag holder. It is labeled for RV use but is this safe for the side of a 5th wheel? Anyone here used this item? Any experiences at all?
That is why I went with the suction cup route. Easy on, easy off. I guess I should not be surprised that there would be some that wanted to use it a a permanent mount. Shaking my head.Btw. I only intend to use when in a Park. Removed on travel days.
I thought that was understood but based on a reply on another forum I thought I’d clarify.
Mine arrived. So far, I am pleased. The one I have must be mounted on a flat plain. I tried to affix it to the hood of my coach but it is slightly rounded thus I could not get both suction cups to work. The suction cups are very robust but I'm sure "they are not forever"! I expect to have to check them weekly to make sure they stay secure. Just an FYI, Where it is mounted in the photos is just for test purpose only. I will find a more appropriate place later.For Christmas I received a suction cup flag holder. It is labeled for RV use but is this safe for the side of a 5th wheel? Anyone here used this item? Any experiences at all?
Thanks for the input. Two different forums and I haven’t heard any complaints.Mine arrived. So far, I am pleased. The one I have must be mounted on a flat plain. I tried to affix it to the hood of my coach but it is slightly rounded thus I could not get both suction cups to work. The suction cups are very robust but I'm sure "they are not forever"! I expect to have to check them weekly to make sure they stay secure. Just an FYI, Where it is mounted in the photos is just for test purpose only. I will find a more appropriate place later.
I will update down the road once they have been used for a while.
Darrell
My mount is a little heavy (almost 4 pounds) and then adding the pole (almost 2 pounds) makes it so much so that I would not want it on a window. Then one must consider the drag that wind would add from the flag during a stiff breeze and I would be scared that the window could either break or be pulled from its frame.As with anything pressing against a painted surface, scratching can take place. Clean surfaces very well before mounting, or better yet mount to your windows!
