Question Magnum inverter settings for LiFePO4 battery
lostinfla
Professional nobody
Dutch Star
2021 Willys
New Li capable inverter installed and have the new 460ah Lithium coming in on Tuesday. (cutting down on the bank capacity from the 8 flooded 6v) Specs from the manufacturer have charge voltage at 14.2, float at 13.6 and max charge at 200a. I believe I first have to set the bank size and then go to charger setup. Has anyone gone through the programing that could educate me with non electrical engineer terminology? I believe I have a slight handle on it, but just wanted to ask for some guidance as to what to watch out for. Thanks!
Your max charge rate should not exceed your GEN breaker capacity.
your battery should have a recommended rate about 2c. I am guessing 90 amps. Jim, do you have the ARC-50? do you still have a Magnum system should be the first question.
Recommended charge current per specs is 50a but that sounded too low to me for a max of 200a. I have a new Magnum 2812 -L-U which is Lithium capable. I also have the ARC panel with Magnum BMK reading SOC.
That will put you at approximately a five hour charge from stone cold dead. I would think somewhere between 80 and 100 would be fine. Some on here say don't do it, but I charge my two 206 ah to 100% and let them cycle down to near dead. I have the final stage in the ARC set to silent. Based on your other settings, this runs the charge up to 100% and then all the 12v use drains them down to around 8-10% before the charger turns back on. The only issue is you need to check your battery charge the day before you start rolling. You could be starting off with a almost dead battery. If needed change the final stage to float. That should engage the charger and you will be full up when you roll out.
Is it possible to set it up to draw the battery down to like 40% then kick the charge in? What would be the settings for that and is that a viable option? I'm using the "Custom" settings on the panel. BTW This is the battery I'm using.
I'm using the Custom settings, and all they show is Absorb, Float, EQ and EQ done. I think the CC/CV settings are what you're using.
The Final Charge setting isn't under the battery type settings. It's a separate item near the bottom of the main list. The choices are Multi, Float, or Silent.
I think the last selection under the custom battery "branch" is equalization time, which should be the minimum setting. If you continue to roll the dial to the right you should find something about final stage. there you select either float, silent, multistage and something else. After that selection is made you should find the rebulk option. I am saying all this from memory so it may not be perfect. If you run into problems, keep typing we will TRY to help
This should work better
I saw that vid briefly when doing research earlier, but am studying it now. So, should I use the "custom" or CC/CV profile? I would guess either one would work.
That is what I use
Here is an interesting video by Magnum on the ME RC controller series
Thanks Joe, my panel only has the options of CC/CV or Custom for Lithium. Here's a stupid question though: should I still hook up the Magnum battery temp sensor that bolts to the Neg terminal? I'm not sure it's going to be effective there.
Thanks for all the info and help here! I finally got my brain wrapped around how this thing works and using the CC/CV profile I am tweaking the charge parameters to get the percentages where I want them. Everything seems to be working great! 👍
I'm sorry Jim I have been completely out of pocket. I use the custom setting. Glad to see things are working for you.
