Answered Question about GPS
roxie
Hello. Purchased 2025 Newmar Baystar. Looking for best GPS system for a motorhome. Looking for free app type that allows height to be considered. Any suggestions greatly appreciated !! Had a 40' 5th wheel for 11 yrs prior to buying this motorhome. Have been camping for 50+ yrs...pop-ups, tag along, 30' 5th wheel then 40'. Thank you for any suggestions!
Make a gallant effort to stay clear of the Garman 890, which can't find it's way home from the grocery store, let alone guide a 50,000 lb RV from point A to point B.
I'm sorry, that's incorrect. It will get you there, but it will go out of it's way to find the worst route possible.
YMMY.
YMMY.
I have an 890 and have not had routing issues with it??
And I'm happy for you. But I've NEVER used it even one time that it actually picked out the best route. Not even once.
In some cases, it put me into such a tailspin that if we followed it, we would have found ourselves in serous problems. But your milage may very. It just hasn't worked for me.
No issues for me either. It’s important to have the parameters for your RV setup correctly and not include toad in the length of your RV. It’s good to have it connected to your phone for live traffic but not auto reroute. Devices like this are only as good as how they are setup and used properly.
OP appears to be asking about an app. The only app I have used that takes into account RV parameters is the one put out by RV Life. I haven’t used it in years, but it was decent when I was using it.
As far as an app goes I switched from RV Life to inRoute.
inRoute is less expensive and has worked really well for us when planning trips.
@roxie can you clarify what you're asking? Are you looking for a GPS to navigate with or an app to plan travel with?
We need a free app that will give directions for height specific. Don't want to be on a road with bridge for 12' when the rv is 12'10". If none available Garmin 895 or 1095 will be checked out, as suggested. Thank you.
Okay, you're looking for an app that runs on a mobile device like Waze to navigate with that takes into account RV parameters? So if anyone knows of one, that seems what they're after otherwise Garmin...
For the most part, RV Life works well, but once it took me into a narrow residential area.
Unless I fear some upcoming problem, I far prefer using Waze which uses Google maps. RV Life uses Here which, IMHO, is inferior to Google and Apple maps.
(Map wise, Apple's is better than Google's, BUT I like the other info that Waze provides: police, road obstacles, cars stranded, etc.)
Hi Roxie and others, if I can throw in my $.02, please. Personally I wouldn't use my phone as my primary guidance system, there are way too many variables to trust a very, very expensive camper on it. Use your phone as a supplement to a good RV GPS System. We too have chosen Garmin, we set all of the sizes, weights, propane in the system so it knows how to route w/o issues. I like Waze on my phone w/o a route for better up to the minute issues.
My suggestion is Garmin, they make a few different RV specific models in different sizes and price ranges.
Got it! And I'd love to love this unit, but it's been unreliable since the first time I've used it. So if I've set it up incorrectly, please tell me how to fix it so that I can begin to trust it.
I really love the turn by turn guidance, and the amount of time it gives till the next turn, etc. And I keep it honest by downloaded and printing directions from RV Trip Wizard. Which is what I would suggest everyone do regardless of what GPS they are using. But that aside, an expensive device by Garman (the king of GPS) should work better than the 890.
I have the following settings:
  • Vehicle is Motor Home
  • 45'1"
  • 45,000 lbs
  • No propane
  • Fastest Time
  • Allow toll roads
  • Avoidance
    • U-Turns
    • Carpool lands
    • Unpaved roads
If I'm missing something, please point me in that direction.
Below is an example of what I've come to expect from my 890. In the following example, you're coming from the top down, as indicated by the 1st green arrow. The correct route would be to turn left where the 2nd green arrow is, and follow that road to Hwy 40. Turn left and go to the destination. These are all very good roads, no construction, no obstacles, etc.
The 890 wants me to pass the correct road and go down to where the red arrows start. Turn left and then follow the red arrows all the way to the destination. This route takes you through the historic area of Ocala where the roads are quite thin, stop lights every couple of blocks, and really someplace you don't want to drive a 45' Class A towing an 18' truck. (Almost 65' in total length)
So will it get you there? Yes. Will it use the best guidance? Not in my opinion.
EDIT: The route is easy to duplicate. If you currently own or have access to the 890, program it to leave a destination north of the Silver Springs/Ocala area, and have it plot a course to Wilderness RV Resort. I'd be interested if your results mirror mine. If yours chooses the correct route, then it's mine that must be set up incorrectly.
