It’s important to have the parameters for your RV setup correctly and not include toad in the length of your RV. It’s good to have it connected to your phone for live traffic but not auto reroute. Devices like this are only as good as how they are setup and used properly.
Got it! And I'd love to love this unit, but it's been unreliable since the first time I've used it. So if I've set it up incorrectly, please tell me how to fix it so that I can begin to trust it.
I really love the turn by turn guidance, and the amount of time it gives till the next turn, etc. And I keep it honest by downloaded and printing directions from RV Trip Wizard. Which is what I would suggest everyone do regardless of what GPS they are using. But that aside, an expensive device by Garman (the king of GPS) should work better than the 890.
I have the following settings:
- Vehicle is Motor Home
- 45'1"
- 45,000 lbs
- No propane
- Fastest Time
- Allow toll roads
- Avoidance
- U-Turns
- Carpool lands
- Unpaved roads
If I'm missing something, please point me in that direction.
Below is an example of what I've come to expect from my 890. In the following example, you're coming from the top down, as indicated by the 1st green arrow. The correct route would be to turn left where the 2nd green arrow is, and follow that road to Hwy 40. Turn left and go to the destination. These are all very good roads, no construction, no obstacles, etc.
The 890 wants me to pass the correct road and go down to where the red arrows start. Turn left and then follow the red arrows all the way to the destination. This route takes you through the historic area of Ocala where the roads are quite thin, stop lights every couple of blocks, and really someplace you don't want to drive a 45' Class A towing an 18' truck. (Almost 65' in total length)
So will it get you there? Yes. Will it use the best guidance? Not in my opinion.
EDIT: The route is easy to duplicate. If you currently own or have access to the 890, program it to leave a destination north of the Silver Springs/Ocala area, and have it plot a course to Wilderness RV Resort. I'd be interested if your results mirror mine. If yours chooses the correct route, then it's mine that must be set up incorrectly.
