FYI Starlink Mini on sale - 299
Perfect. Thanks @Neal.
Starlink mini router, from a quick google search, has a 150ft range. Your coach is only 43ft, any wi-fi router should suffice for that length.
There are alternative options depending on your coach Wi-Fi setup. For example, I use a pepwave to broadcast Wi-Fi to my phone and all devices in the coach. You could consider the Starlink Wi-Fi like Campground Wi-Fi so you bring in the external source (WAN) to your pepwave, if you have one, and then that goes out of the pepwave like before. I actually use an Ethernet connection on mine so my Starlink connects to my Pepwave over Ethernet and I don't even use Starlink's wi-fi.
Short answer YES
Long answer posted, you have options to keep things even simpler if needed and change Internet sources without ever having to change Wi-Fi connections on streaming devices, TV's, computers, Alexa's, etc.
Neal,
Great explanation! I’m doing exactly as you describe using Starlink WiFi as a WAN as my source via a Peplink BR Mini 5g. The Starlink Mini has provided a great signal for our 35’ Bay Star and it located on a Flagpole Buddy mount. It’s worked so well I ditched Dish network and just use Apple TVs everywhere now. So I have same YouTube TV in the coach as at home.
Bill
Short answer YES
@Neal Are you using the Gen 3? When you say Starlink connects to your pepwave via ethernet is that the dishy direct to the pepwave or Starlink Router to Pepwave?
The last used Starlink for me was the Gen2 with the motor in it. I purchased the Gen 3 "Standard" which I have yet to use but my coach is wired for it via a PoE power supply so when I connect the ethernet from the dish into it, there is an ethernet that goes to my Pepwave BR1 Pro 5G WAN port. This is how I bring in outside Internet (aka WAN) via SL into my Pepwave. The alternative option is connect the Pepwave to the Starlink Wi-Fi just as if it was Campground Wi-Fi, and then your Pepwave broadcasts its Wi-Fi to your devices within your coach so you never have to change Wi-Fi connections.
I now added (not yet received) the Mini which I can use in the car, plane, or RV. Long ago I bought the flagpole buddy adapter for both the mini and standard (gen3) so either of those will work to go on the pole on the ladder mount on the back of my coach. I will have both dishes on hand anytime I travel, the mini will likely stay in the car for emergency use.
@Neal Thanks for the info. You confirmed my thought regarding a PoE is needed for the antenna if the Starlink router is not used.
Here's my post on it:
My question is more about the range of the wifi signal of the mini. IOW, if it is on my dash, will I be able to stream on all TVs including the bedroom and exterior ent center?
I have only used it inside and around my motorhome so can't help you there. My understanding is you can hook it to your own router and use it for ethernet or wifi.
Does anyone use this app for satellite location? Is it necessary?
My Starlink Mini arrived yesterday and my Amazon pallet of Mini gear is in the garage :rolleyes:
Forced activation will occur 30 days after shipping and I hope to be in the coach at that time and use it. I did a quick google and you can't power it with PoE due to power demands so that's fine, I have the various cables to use other sources as needed.
What's even better is that this Starlink Mini is such a thing that now every 3rd post on Facebook and Instagram is now a Starlink Mini accessory ad! :( Mainly power or mount solutions. Some neat innovation to see at least.
We received the standard Starlink system for Christmas from our daughter. She didn't like it when we are off grid with no communications. Sometimes we kind of liked it. Anyway If I could ask a question about this. I am thinking of going with the base $50/ month plan. For you who have used this do you find this adequate in most cases?
This all depends on what you use Internet for. Do you stream TV or videos (YouTube TV, Netflix, etc. etc.)? Do you browse social media often as they can have high bandwidth usage from the images. So it all depends. You can minimize Starlink bandwidth usage by using cellular on devices with cellular plans, for example I'll turn Wi-Fi off on my phone so that my phone uses my Verizon unlimited and not Starlink bandwidth. You just have to be smart and be careful and track usage to learn what you're using and what you really need to pay for.
If you could only have one, would you go with the standard starlink, or the mini?
My use case will involve teams meetings, email, browsing and streaming.
I'm pretty much an average business user, not overly tech savvy, but not a complete novice either.
Not wanting to drill holes and route too much wiring....simple and reliable is what I'm after.
I have been using the TravelFi system and it has worked fine for my needs so far but I'd like a little better performance.
Standard. This is what I have and will use for normal Internet use. The mini is for the toad, airplane, backup etc. The larger dish is always going to be better, at least I would think. I imagine someday Starlink may come packaged in a dome, who knows...innovation continues.
We have the standard and if buying again, would get the standard.
Reason: believe the larger area will provide a better signal and we are still working and Internet is not just a luxury but a requirement for work purposes.
I set the Starlink up today and I was amazed at how easy it was. Set up once unplugged and moved to another spot and reconnected. For an old guy, it was easy. We did the mini, it should be fine for our needs.
It's only going to get better. Glad to hear all went well. Amazing technology.
I decided to jump on this deal and I have one on the way.
Question: I see “mini routers” available. What are they for?
FOMO is real :) But it's a great device and it fits so nice in the little carry case I bought and linked above.
The mini has its own built in router so it's not needed, however, it's only Wi-Fi 5 - still fine for our needs. I think the additional router offered allows a mesh setup, i.e. multiple routers talking to each other and new Wi-Fi technology I presume. Unless you have issues with Wi-Fi I would not get it.
Amazon awaits your Starlink mini accessory collection.
i've been watching that for a few days and finally decided that it might go up in price so I checked it this morning and it had gone down yet more - about $294, so I ordered the heck out of it, and when I checked back later it had gone up to $317. Weird.
