Tip Tips for staying cool in the summer in your RV
Staff member
RVF Administrator
Tip 1: Stay ahead of the heat
If you wait until you're hot to turn down the temps in your coach you'll never catch up. While it may be slightly uncomfortable on the cold side earlier, try to keep ahead of the heat indoors
Tip 2: Balance your AC's
I have a 40ft with 2 AC's. I typically keep the front AC one degree lower than the rear UNTIL recently. The front AC is ducted to help cool other zones and it's probably the AC that will have the highest runtime on it and therefore be the first to go south on you. My recent discovery is to actually keep the temps in sync so for me 73 or 74 on both zones. Let the rear AC(s) help the forward zones and even the load.
Tip 3: Close the bedroom door
Depending on where your thermistors are (the sensors for the temps in the zones) you may have one AC such as in my coach the rear zone is right next to the front zone thermistor. By creating a barrier to that thermistor it won't sense cooler than it really is causing the front zone to shut off too early.
Tip 4: Leave your bathroom doors open
You have vents and a good airflow in the bathrooms. Allow that cool air to come out and help the adjacent rooms.
Tip 5: Block the heat
5a) Get your shades down early and block the heat from getting in. Know your orientation by using the Compass on your smart phone. Know where the sun will rise and set so you can be prepared to block the sun.
5b) Extend your awning to keep the sun off the walls of the coach. It's up to you and your risk if you trust wind/motion sensors to auto close them, rule of thumb for safety is to retract the awning when not home.
5c) Use 3rd party products such as Magneshade to block the sun from entering the glass. This discussion is not about effectiveness of these 3rd party products, there are other discussions or you can create your own thread to ask, but block the heat is the theme.
Tip 6: Insulate
Fantastic Fan vents are areas of zero insulation. Consider installing Camco insulation pads to add insulation. These will fit behind wood covered fans as well such as I have over the kitchen. Pull down the wooden grill cover as it's just two drawer latches holding it in place then install the insulated pad. I store these on the side of my washer/dryer when not in use.
https://www.amazon.com/gp/product/B0024E6QX0/?tag=rvf01-20
Have tips to share for newbies to keep cool, please share your lessons learned.
Time to review or add as the heat is here. I have my camco insulation pads in place, magneshades on, keeping ahead of the heat and enjoying the air conditioning!
Bumping this thread as the heart of summer is upon us.
I agree with getting ahead of the heat. We usually run the generator along with AC s ( we only have 2 on our 37') while on the road. Makes it much easier on the system when arriving at the campsite as it doesn't have to overcome a high heat load. We also use the insulation "pillows" in the fan openings, Magneshade on the front and foil material cut to cover windows including the windshield to help on really hot days. The thing that kills me is the placement of the temp sensors. I realize they should be on an "inside" wall, but on our DS, the front sensor is only a couple feet ahead of the sensor for the rear air which makes it hard to get the coach evenly cool. We also use 2 or 3 small oscillating fans to keep the air moving. Neal, how did you make a barrier to help isolate the front sensor?
I keep the bedroom slider 3/4 closed. Enough room for dawg to go in/out.
Well, that was too simple for me to figure out. Thanks!
This reminded me of an old joke.
A Russian and American astronaut were discussing their countries space programs. The American was boasting about a zero gravity pen they developed for millions of dollars ensuring it would write in any conditions.
The Russian responded, We use pencil.
On travel days with our trailer, once we arrive, I open the door and use the bathroom fan to vent out hot air and bring in cooler air before firing up the AC.
What, no mention of elevation? That would be my first step, going to elevation once summer started... and dropping back down once fall rolled around. Just my $.02 on this topic. :unsure:
Still, kudos to the OP and others for the helpful suggestions... :cool:
I used a UV reflective paint on my RV’s aTT’s the reflective about 75% of the heat rays on the roof. Then tinted the side driver and passenger windows, then tinted the top 2ft a lower 10” of the front window. Tremendous help in reducing heat.
Your windshield appears to be widescreen format. :)
