J&JD
- Nov 3, 2019
- Fremont, California
- Dutch Star 4018
- 40’
- Freightliner
- Cummins ISL450
- Jeep Wrangler Sahara
Good for you you lucky dog. Very happy for you. I haven’t had time to figure mine out yet but I’m starting to believe that my problem is likely to be the right air bag or the lines leading to it as the AA controller seems to check out ok. Still a mystery as to why a leak as big as mine hasn’t been located by 3 repair facilities.Today I went back to the coach for the routine exercise of dash AC, roof ac/heat pumps, GEN, and a drive. During the drive something was unusual, tank 2 air was not cycling like it did in the past which was always a concern and subsequent replacement of air bags. Hmmm, okay, is that good or bad? Then upon return I intended to extend all slides and do an air level test for an hour. Well, I didn't care to sit there so I parked it and did an air level test with slides in for 20 minutes. It did not budge. So it seems the tank 2 cycling could also have been an indicator of the bad solenoid. Always good to learn more about the system and I'm also happy to have discovered Joe at HWH that handles support and he was great to work with. Hope @J&JD can find the cure to his saga soon as well as his seems beyond the solenoid.
Newmar does not carry them & referred me to Gaffney and also gave me a DTNA 800 number to check. DTNA gave me two part numbers that they assured me if ordered together would get me the bag. Went back to Gaffney parts, gave them the two numbers and they laughed at me saying the second part number was for the nuts that hold the bag in place. They had those….many hahas later. They also said there are no bags in the entire Freightliner system so local Freightliner dealers are also out. Sure hard to believe. Gaffney said they have been back ordered since early March from Germany. Wonder if the new tariffs are having any interesting new affects on our parts system? Hmmm.Does Newmar parts carry them? What about your local FL service center, can they source any? The ones near me are Excel Truck Group in case you wanted to call them just for "fun"
Home - Excel Truck Group
Excel Truck Group offers the best quality New & Used Trucks for you. Discover your perfect Truck today. Click here to browse our selection.www.exceltruckgroup.com
More like incinerate your plastic. Keeping these devils in top running condition is just a bit expensive for sure. But, well worth it for the wonderful life experiences they give us.beware it can melt some plastic!!!
Remember, compare to buying new and all of the sudden your "fix it budget" quadruplesMore like incinerate your plastic. Keeping these devils in top running condition is just a bit expensive for sure. But, well worth it for the wonderful life experiences they give us.
