Battery Questions
The photo with blue circle did show terminals at the end of a series pair. If there is no charge source or recent surface charge on the bank…you should have at least 12.6v. Without a load 12.2v is considered 50% charged. 12.0 would be even less…
It is a good idea to be able to identify the raised symbols on the battery casing. They are labeled to identify the polarity Plus +, or Minus - . When you see jumpers attached between “+” and “-“…that is a series connection. It adds the voltage, but keeps the amp hours the same. If you see jumpers attached between “+” and “+” …and also “-“ and “-“…that is a parallel connection. Parallel connections keep the voltage the same, but add amp hours.
Newmar wires the eight battery bank using eight 6v batteries. They are trying to achieve a 12v system to be compatible with your coaches normal dc voltage. So, they take two batteries and series connect them. They are 6v (6.4v) and 210 aH generally. So in series…this yields 12v (12.8v) and 210 aH.
Next they replicate this three more times…and connect the four sets in parallel. Connecting positives to each other and negatives to each other. This keeps the voltage at 12v (12.8v)…but gives you more amp hours 4 x 210aH = 840 aH.
Don’t worry…the first time you deal with these things…it is overwhelming to the eyes. Complete chaos going in with all of those cables. Take your time…and start with identifying the positive and negative terminals. Get an overall picture of how they are organized. Then take one step at a time… Identify the short jumper cables between just two batteries…nothing else on those terminals. That is your series connections turning two 6v into a pseudo 12v. Then identify the slightly longer jumpers going between like terminals…this are your parallel.
It is important to be able to identify these…so that you can get them filtered out.
The final steep is to identify the actual connections to the coach.
Generally…there are three sets of connections. You will have a plus and a minus..and they will connect to those blue circled ends of a pair of batteries. Or at opposite ends of the four sets. One positive and one negative.
The devices connected are
1) Inverter
2) House Distribution
3) Bi-directional relay
Note: the negative for the bi-directional relay is bolted to the frame rail…instead of running a cable the entire length of the coach.
Again…it can be daunting..,but once you do this, it will be much easier to understand what is going in. Very useful in troubleshooting..and super important if you decide to replace your batteries, or pull them for routine maintenance of the bay.
Here is some information on batteries, that owners of lead acid batteries would do good to learn. Nothing Here applies to lithium owners.
Thank you for all the replies.
Much appreciated
Hooked the jump pack up to house batteries.
That got the voltage up enough to trick Silverleaf into charging on shore power.
Now it's hooked up getting a good charge.
Did buy another charger but then thought to try the jump pack.
Will have to hook it up some time see if it reacts like the other one.
Chassis batteries are junk.
They went dead after two days, even with chassis disconnect off.
I'm learning.
Have another question, different topic kind of, will do a search or start another thread.
Feel like I accomplished something today, so it's time for a beer.
Thanks,.
I will check it out.
