BigRig
- Sep 8, 2024
- Virginia Beach, VA
- Ventana 4037
- 40'
- Freightliner
- n/A
I usually start at the fuse...in the cord reel bay. And never find it blown. Then replace the motor. Seems to work everytime. It's basically a windshield wiper motor...the controller controls the polarity of the power to the motor and cuts out at a preset amperage (stop limit). The thing is...these things are not well sealed and get grime in the plastic spiral gear inside. If someone steps on the step when it hasn't reach full up or full down it will crack the gear, and of course possible the motor does fail.
AM Equipment, they have a few different ones, torque and bolt size are the main differences. I’ll update post w/part no.Thanks Charlie!!
Sounds like this has happen to you more than once. Where did you get the replacement motor. I am pretty sure I have seen the electric step "owner or install manual" in my Newmar paperwork. Let me look and see the manufacturer.
Thanks so much! I did find the Electric Steps Owner's Manual. The manufacturer is KwikeeAM Equipment, they have a few different ones, torque and bolt size are the main differences. I’ll update post w/part no.
I keep a spare motor and controller in the coach. The other handy items are oasis pumps, and water pump controller…if your coach is equipped with one. Twice, I have had the step motor stop working.
Opps I added a post without first seeing you had tracked it down.Charlie,
Attached are the first two pages of the Kwikee Owner's Manual. The part number I am coming up with is 1101428. I found it on the AM Equipment site. It's the 214 Series and available with several options. The option with the part number comes with mounting screws and without the pinion gear.
Below is a link to the AM Equipment parts page.
Curious if you ordered without the pinion and reused the pinion from existing motor. Kind of seem like that might be a bad idea. Especially if the pinion gear is messed up.![]()
214 Series DC Gear Motor - AM Equipment
Original equipment replacements for LCI / Kwikee®www.amequipment.com
Actually, looking at the gear housing it appears the motor's shaft might just slip into a "receiver."
Any insight is appreciated.
Thanks,
No problem... In addition to the motor, and controller spare...I did purchase these wire dongles. I think you'll find that guide you referenced has you use these in troubleshooting. I have them...hope not to have to dive that deep to get things sorted.Charlie,
Confirmed the motor has a 2-pin connection so all set there. Not so much on the controller. I am having trouble figuring out the part number to order. Attached is photo of existing. Any chance I could get you to send photo of what you ordered?
Thanks! I did order the 4-pin connector (dongle), same part number as yours, as it was identified in the trouble shooting information in the Owner's Manual. But as you indicted that appears to be digging pretty deep. It appears you can get some pretty good "feedback" using a multimeter to test power, grounds etc. on the vehicle side of the 4-pin connectorNo problem... In addition to the motor, and controller spare...I did purchase these wire dongles. I think you'll find that guide you referenced has you use these in troubleshooting. I have them...hope not to have to dive that deep to get things sorted.
