BigRig
- Sep 8, 2024
- Virginia Beach, VA
- Ventana 4037
- 40'
- Freightliner
- n/A
Joe,
Thanks for the help!
Joe,
Charles,No problem... In addition to the motor, and controller spare...I did purchase these wire dongles. I think you'll find that guide you referenced has you use these in troubleshooting. I have them...hope not to have to dive that deep to get things sorted.
I'm always happy to hang out and talk rv stuff. Sorry, I do not remember how long it took for the part to arrive. One motor ( I have ordered a couple of them) I used to replace a friends motor...and he just ordered one and shipped it to my home. Never know what kind of parts a few Newmars parked nearby might have.Charles,
Just wanted to say thanks again for all the assistance.
Motor & Controller ordered!
Good news is all the "4-Pin trouble shooting" has been accomplished and it all checked out. For example, the red wire has 12 volts, etc. (each wire has its own positive results) and all grounds checked for continuity.
Has to be the motor or controller. So now we wait for parts.
Controller will be here Friday (from Amazon).
AM Equipment sent e-mail confirming receipt of order and processing. but no delivery estimates. Wrote back and asked if they could provide delivery date or tracking information. Have not received a reply.
Do you recall delivery time when you ordered from them?
Thanks for the heads up! Fingers crossed!!Recently I had the same issue. So after some expert consultation (YOUTUBE) I thought I would simply cover all the bases. I ordered a new motor, a new screen door contact switch, a new controller, etc. Received via AMAZON then went to work replacing the items. I used shrink wrap and neatly ran all new wiring. I was proud of myself to such a professional installation. I managed to crawl out from under the step and gave it a try. Nothing. I finally had to call in a professional. At $80.00 per hour, and after a brief looksie he discovered that my controller was no good. My brand new controller, made in China, didn't work right out of the box. I purchased one from the RV repair man and it worked flawlessly. I pray your installation is flawless. Just wanted to share so you may want to check new parts if necessary. Blessings
Charles,I'm always happy to hang out and talk rv stuff. Sorry, I do not remember how long it took for the part to arrive. One motor ( I have ordered a couple of them) I used to replace a friends motor...and he just ordered one and shipped it to my home. Never know what kind of parts a few Newmars parked nearby might have.
Sounds like a sound practice. Thanks!When we leave our rig, we turn off both water and propane to avoid any potential issues from water damage or gas leaks.
I made it work good enough. I ended up adding a relay so that when it sensed the correct condition in the override or door wire, it would open or close or whatever I needed. It was a few years ago, so I don’t recall the exact configuration. The change was on the controller side of the 4 pin connector, so if I ever have to change the controller again, the changes I made will be removed along with the old controller.Thanks for the tips!
Curious what you did after you found out the controller from Amazon did not function properly? Did you purchase one from Kwikee/Lippert?
