drainmaster.com
My issue is, the gray usually goes to 100% late at night due to my neglect, then it's go outside and under the FWS again.I am not sure I could do it….i am so afraid of a slinky pipe failure when I am not there to shut it off…. Gray would probably be ok…but not sure I would feel good about dumping black unseen.
I am and I love them. I go in the half bath, push a couple buttons and the tanks dump. I used Barker Auto Drain valves. Here is the link Auto DrainWho's using them, what's your opinion of them and what brand is the most reliable?
No, it's not hard. I mounted mine on the pull out "thing" in front of the kitchen sink as that was the easiest path I knew to the basement. Underneath the kitchen sink, on the floor, is a plastic cover plate that is the location where the wire bundle comes up in that chain link plastic contraption. So it's an easy path from wet bay via basement up into kitchen slide.Where do you guys mount the internal buttons? And was it hard to run the wires? Is there a way to run it from your phone?
