Chuggs
- Nov 3, 2019
- Ventana 4037
- 40’
- Jeep JKU
I used the Barker AutoDrain. They come with wiring that basically is basic trailer light 4-conductor. Two leads to the motor, the other is for the red light to illuminate if the valve is not closed.Does anyone here know if it's possible to add another set of switches to the Barker system (for the wet bay) without interfering with the original controls?
So, I have the supplied valves mounted. Then I mounted a Sonoff 4-ch wireless switch. It uses WiFi, and also has a rf key fob option....and buttons on the relay housing if you want to use them to activate a relay. And yes, there is an Alexa Skill, so you can even tell Alexa to open and close the valves. You wind up with 2 pairs of motor wires coming from the Barker switches and 2 pairs coming from the sonoff. I ran these to a 3 position ON-OFF-ON switch with four poles... This is an important thing. It keeps one source from shorting out the other...and it safeties your valves in the center OFF position so that no accidental activation can occur. I highly recommend the OFF position at all times that a secure sewer hose connection has not be securely connected. Nobody wants sanitary spills.
So, when I want to dump...I secure the hose, flip the switch to the desired control ... either Barker toggles switches, or Sonoff relay...and activate. Finger press on Barker Toggles...or Sonoff can be activated by buttons on the relay case, or thru a smartphone app EWelink, or if the smartskill has been set up...voice command thru Alexa.
