Fuel mileage increase after repair
BGMAC
RVF 1K Club
Cypress Inn, TN
Forest River
Georgetown XL M-369DS
37ft
F53
Titan V10
2024 Chevy Colorado
About week ago I set out on a trip to Florida. I got about 60 miles and the throttle quit functioning. The engine just went to idle. I pulled over and pulled out my ODB2 scanner and had a code indicating throttle body issue. I reset the code and got the rv going again and headed home. I made sure I did not run at the same cruise speed thinking the might be a bad spot in the sensor. Got home ordered a new throttle body.
When I received it, I installed it. With a new throttle body you have to clear the ecu throttle memory or reset to do a throttle relearn, then run at Idle for 15 min.
Well then I took off on my trip again. The engine seemed to run much better. On my first fuel stop I got 7.5 mpg which was much better then my 6+ mpg. On my second stop I got 8.5 mpg. I could not believe it. I went back and checked to make sure I filled the tank full.
Now I know terrain has a lot to do with, but I got the 6+ on the same trip several months ago ago.
I’m pretty sure doing the relearn had a lot to do with it.
Just thought I’d pass it on.
I assume your fuel mileage is hand calculated?
Well I don't know what was responsible for such an improvement, but that's great!
Yea, I can only think the clearing the memory had a lot to do with it. It came at a good time. Around my daughter’s house in Clermont Fl gas is $3.20 per gallon
Here in the Phoenix area 87 octane is running around $3.79 a gallon
3.09-3.29 here.
$2.19 for regular in Oklahoma City.
$4.19 in Southern WA state
