Dual Pane option on a Brinkley?
CaptainGizmo
SoCal...relax, we're one of the good ones! ;-)
Newell
2020P
Cummins ISX
2021 Grand Cherokee Trailhawk
When you spec a Brinkley, one option is Dual Pane windows.
What's interesting is that, with the full body paint, the wall construction is different and they add insulation.
So, perhaps the $2400 option of dual panes would be a good choice to give a bit better insulation even for someone who travels in moderate climates.
Chime in, if you have experience/input!
Dual pane windows are problematic in a moving house. Fogging is an issue in a rv. Judy D
Yup, you don’t need to tell me just look at my bank account. Fact is all of the upper-tier coaches have them and the real problem is there’s pretty much only one source for them and they stink.
That said, I understand that the windows on the Brinkley are not sealed. Not quite sure I understand the benefit if they aren’t but still worth the discussion.
Had double pane and dual pane both are different / dual pane is completely sealed ! had dual pane in both a TT and a Class C and had no issues TT 10 years / Class C 12 years and 90,000 miles and no problems !!! Both types of windows are good to help keep you cooler in summer and warmer in cooler weather !!
Double and dual pane are different names for a sealed glass unit with 2 panes of glass and a sealed void filled with dry air or an inert gas. To have what you describe, the 2 panes would have to be completely separate and full ventilated, otherwise, it would often have condensation between the panes. It would still have condensation at times. Also now there would be no insulating air space - the ambient temperature against the outer and inner pane would be the same. Glass in the 1/8" to 1/4" thickness range has no insulating value (the U-value~=1.0). So you would have added a complex framing system to hold 2 totally independent panes of glass for zero gain in insulating or sound attenuating value.
