Can't find my converter!
Christopher0305
Oklahoma City
Winnebago
Adventurer 38T
39'
Chevy Workhorse
2007 Winnebago Adventurer 38T. Need help finding the location of the converter. My batteries aren't charging from shore power or the generator. They will charge from the engine alternator or a direct battery charger. The original operating manuals list three possible locations for the converter, but I've checked all three and no luck.
Have you tried looking between the frame rails in the forward part of the basement?
Gemini says to look behind the 120v breaker/12v fuse panel typically located in a cabinet or in a lower cabinet in the kitchen area or under the bed. Based on reports from other Winnebago owners it is fequently described as being behind a panel or wall near the refrigerator or the main electrical center, and is NOT easily accessible.
Furthermore, when plugged into shorepower, turn off anything making noise (a/c) and listen for the converter's fan
It also says you can find your specific year and model wiring diagtam on the official Winnebago owner resourcrs website.
I have exactly same issue on my 2012 Roadtrek Popular 190 Chevy. Someone said it's combined in the inverter, Tripplite in my case, but I can't confirm that so far. I just had a new transfer switch installed and that could be the key to my problem.
For you, from ChatGPT:
On a 2007 Winnebago Adventurer 38T, the converter (the unit that takes 120 V AC shore power and changes it to 12 V DC to run lights/12 V systems and charge the batteries) isn’t in the engine bay — it’s inside the living area and typically installed near other electrical components. (Winnebago)
📍 Common Locations for the Converter​
Here’s where it’s most often found on Winnebago Adventurer floorplans similar to the 38T:
  • Under or near the refrigerator: Many owners report the converter/charger mounted on the floor behind a panel under the fridge or behind a lower cabinet near it. (RV Forum)
  • Behind lower kitchen cabinets/drawers: It may be behind the bottom drawer(s) under the stove or sink area— you sometimes need to pull these out to access the converter. (IRV2)
  • Lower cabinet face in galley/living area: The official Winnebago operator manual notes the converter is generally installed in a lower cabinet area in the galley, living space, or beneath a bed depending on the floorplan. (Winnebago)
🧠 Tips for Finding It​
  • Look for a metal box with ventilation slots and multiple 12 V wires running into it near the coach’s main electrical panel or breaker area. (Camping World Blog)
  • Check access panels or drawers around the kitchen appliances — many converters are tucked in there to stay cool and out of the way. (IRV2)
  • A converter is different from the inverter (which turns 12 V into 120 V and, if present, is often elsewhere, like in an outside power bay). (winnieowners.com)
If you want, tell me where your 38T’s kitchen and fridge are located on your floorplan and I can give more precise directions!
I think you may be right. I was able to get a look behind the electrical panels from inside the kitchen sink cabinet and it looks like it may be mounted directly above the 120v breakers. I'll pull the pa el off this week to confirm.
The 38T has a forward kitchen layout with entry in the middle of the coach. My electrical panels are in a side compartment on the end side of the kitchen sink cabinet adjacent to the step well. It looks like it might be behind the 120v breaker panel. I was able to get a look behind the electrical panels from inside the kitchen sink cabinet and it looks like it may be mounted directly above the 120v breakers. I'll pull the panel off this week to confirm.
My model has an inverter as well so I'm wondering if they are a combined unit like yours.
They are generally near the batteries. DC does not like distance so they keep the leads short.
I was not maybe right, I only asked Gemini AI. Glad it maybe helped though.
