turbopilot
- Nov 2, 2019
- Prescott, AZ
- LightShip
- AE.1 Cosmos
- Electric
- 2025 Ford F-150 PowerBoost HEV
Interesting twist on the NACS port. It will do DC Fast Charging OUT, but it cannot do DC Fast Charging IN. It is limited to 6 kW IN through the NACS port. No idea why.And DC OUT charging too!
Can you provide further info regarding the "suspension and brakes"?
bruderx.com
Checked it out... I see the similarities.There were a few shots in one of the walk through videos showing the suspension and brakes. There is a trailing link suspension with air bags. Looks like they used a reinforced BAL frame. All four wheels had disc brakes. The whole system is very similar to the undercarriage of the Bruder RV's from Australia.
Home - BruderX
Discover Bruder's ultimate luxury off-road expedition trailers, designed for adventure enthusiasts seeking unparalleled durability, comfort, and performance in any terrainbruderx.com
Agreed“…pretty clear where this vehicle is coming from…
…and the 11,000 lb limit on all G1 R1Ts, and the G2 Dual (like mine) and Quad Max R1Ts. And the expected 10,000 lb limit on the upcoming Scout.“…If I owned an EV tow vehicle this trailer might be appealing but only the high trim level Cybertruck can tow 10,000 lbs. Only the highest trim of the now discontinued Ford Lightning can tow a 10,000 lb load. So this RV will not help most EV truck owners. The new RAM and Ford EREV's will most likely be rated above 10,000 lbs towing…
