MOD My replacement fireplace story.
Tjdave
motorized toy collector
Wa State
Tiffin
Allegro 32sa
F53
V10
2018 Jeep Wrangler Unlimited Rubicon
2018 32sa. Last fall, the blower fan on our electric fireplace started acting up. Barely blowing out heat, and then bit the dust completely. Easy enough, just swap out the fan or buy a replacement Dimplex DF2524L original fireplace. Nope. Discontinued. No direct replacement fan available either. I read about others who have rewired a replacement fan. New fireplace it is. One of the only new fireplaces I could find that would fit the original opening was from Rec Pro. Crystals instead of wood. I'll get used to it. Mounting points on the sides instead of top and bottom required a little modification.
Original fan wiring I didn't want to deal with
Original opening. No room to make taller due to AV equipment. Most fireplaces were taller than the 18" tall opening.
Modification for side mount on new Rec Pro.
New Rec Pro 26"
I'm installing an 18" Recpro that should fit one of my cabinets with minimal alteration, as soon as it warms up a little.
How is the heat output on the new fireplace?
Way better than the original. It blows out way more warm air. I suspect the original fan was having problems for a couple years. Our Tiffin is winterized at our house with the slides in, so I didn't run the fireplace heater very long. I can't wait to really test it out in a couple months.
