Problem Sleeper Sofa - Air Dream Sofa Mattress
BigRig
Virginia Beach, VA
40'
n/A
Based on my Newgle research our Ventana LE 4037 has an Air Dream Sofa Mattress in the Sleeper Sofa which inflates with an air mattress inflator. Problem is it loses air. Wondering if anyone has had this issue and if there are any trouble shooting tips and/or "fixes." It appears the product is available at airdream.net so replacement is an option at about $350. Just wanted to see if anyone else has had this issue and what was the resolution.
Watching.
We're having the same problem.
You can patch it like any other air mattress once you find the leak. Only if it’s on the fuzzy side you’d have to make it smooth and if it’s in a crease it’s not going to happen. Dish soap and water will help find the leak.
Is the inflator where you can access it (and maybe remove it?) They make inflators that maintain the desired pressure. If there's a way to work that into the system it should be a fix provided your leak is "SLOW" 😉
We had an issue with the big plug for the inflation pump. If I can remember right, it didn't quite seal as the clip that kept it shut wasn't tight enough. My wife shoved a q tip in there somehow to make it fit tighter. Sorry I don't have more info as the couch is gone replaced with two recliners. When looking for leaks, use Dawn Power wash spray. It comes out as a foam and adheres to areas nicely showing leaks immediately.
