Smoothest Trailer to tow
The most important attribute for a smooth tow, especially at high speeds, is the size of the tow vehicle in relation to the size of the trailer. A good rule of thumb is that your tow vehicle should weigh more than your trailer. Also make sure that your trailer's load is distributed with 10-15% hitch weight. You won't need a weight distribution/sway control hitch if you follow these rules of thumb. Indeed, these hitches, while they make you feel like you're getting a stable tow, actually decrease your tow vehicle's handling ability, and they should be avoided.
That's 100% not true. A WDH transfers weight forward to the steering axle and rearward to the trailer axles resulting in better, not worse, handling.
Let me explain. When you take weight off the rear axle of the tow vehicle, the rear end is more prone to lose traction and swing out, resulting in a jackknife. Basically, you will not be able to go around a turn as fast as if you had no weight distribution.
Better to have no steering or braking because you have no weight on the front axle, eh?
