Smoothest Trailer to tow
The most important attribute for a smooth tow, especially at high speeds, is the size of the tow vehicle in relation to the size of the trailer. A good rule of thumb is that your tow vehicle should weigh more than your trailer. Also make sure that your trailer's load is distributed with 10-15% hitch weight. You won't need a weight distribution/sway control hitch if you follow these rules of thumb. Indeed, these hitches, while they make you feel like you're getting a stable tow, actually decrease your tow vehicle's handling ability, and they should be avoided.
That's 100% not true. A WDH transfers weight forward to the steering axle and rearward to the trailer axles resulting in better, not worse, handling.
Let me explain. When you take weight off the rear axle of the tow vehicle, the rear end is more prone to lose traction and swing out, resulting in a jackknife. Basically, you will not be able to go around a turn as fast as if you had no weight distribution.
Better to have no steering or braking because you have no weight on the front axle, eh?
That won't happen as long as you stay within the vehicle's gross rear axle weight rating and gross vehicle weight rating. The GAWRs and GVWR are stamped on the door placard of every vehicle. These define the vehicle's loading limits and must never be exceeded.
Everything with a trailer has guidelines and limits.
Too much tongue weight exceeds the limits of trailer, tow vehicle, and safety.
Too little tongue weight exceeds physics and safety of towing.
Too much mass, overall weight impacts safety, comfort, physics, and legal limits.
There is a lot of work involved in picking the exact right circumstances for any trailer combination.
This last hay season I was doing a short run between pastures. I needed to move 80 round bales. I used my 45ft 32gn trailer with 1 ton dually ram.
First load I stack 24 bales. Fit nicely and started rolling.
I noticed right away something wasn’t right. The trailer brakes had to be adjusted and the ram struggled.
Crossed the scale and found that my trailer was 56k lbs each bale was over 1800lbs and the trailer dry is already 9800lbs
The next trips that trailer carried 12 bales. Still over weight but not more than 1500lbs
Did my truck handle it? Yes
Trailer? Yes
But for how long?
This travel was all dirt roads and private property. Imagine highway issues like panic swerves stops etc?
Everything has proper balance.
Actually! You aren't thinking this through. The load capacity depends on balancing the load on the vehicle.
In most pickup trucks the ball is behind axle center by at least 3 foot, usually a little more.
The truck I drive is over 19 foot long. My trailers are rated for 7500 to 8700 Pound GVW at 10% 750 or 870 at the Ball depending on the trailer.
3 into 18 is 6. The fulcrum effect takes that 740 divide by 6 to remove 125 pounds off the steer wheels.
When you look at the box on your truck from the side,the manufacturer placed center line of the axle so when that box was loaded center line of box for proper balance. Yes for proper handling. That loading adds weight to the steer wheels.
The effect of removing weight from steer wheels is not jackknife, it's plow, no matter, over steer or under steer, it is not safe.
There are two ratings on a receiver hitch. The rating are with an equalizer hitch, and without.
I want you safe out there!
Forums are notorious for spreading misinformation. Not intentionally but just as dangerous. Manufacturers publish information,not to sell something,but rather to reduce liability!
For your safety on important topics like this one I suggest you look at us as a bunch of backyard drunks having a party, and go to the manufacturers websites.
You are looking at it the right way. The goal is to not have oversteer or understeer. Zero oversteer and zero understeer is ideal, but if you have to have one, it is generally considered that understeer is safer than oversteer.
A truck will understeer without a trailer but put a travel trailer on it and it will understeer less. The faster you go around a turn it will tend to tend to oversteer. This is because the centrifugal force of the turn acts on the mass of the trailer acting on the hitch ball, pushing the rear of the truck out. Once it starts to oversteer you are in a danger zone. Go just a little faster and the rig will jackknife. This is how conventional towing rigs fail. They do not fail from too much understeer.
All this can be measured in a skid pad test, and in fact the SAE uses such a test in their towing standard. The test measures the g-force of the turn before the tow vehicle begins to oversteer. The more g-force the rig can pull in a turn before oversteer begins, the safer your rig will be.
These discussions about weight distribution and vehicle stability for towable RV's dominate RV the forums. Typically it is like a blind man feeling different parts of the elephant. Rarely does anyone consider the big picture. Most of the discussion is rooted in knowledge of the subject as it was at the end of the last century.
I concede each vehicle should be set up within the SAE and manufacturer recommendations for proper weight distribution. That is largely accomplished by following the towing, hitch weight and FALR recommendations by the tow vehicle manufacturer. That process is pretty crude with chains and bars coupled with hitches that only allow leveling by about 1.5" increments. You look at the manufacturers recommendations then try to achieve the guidelines with the mostly crude and heavy weight distribution hitches currently available.
But since 2000 things have changed with the advent of built in electronic sway control systems in most tow vehicles. These sophisticated systems are much better and precise in controlling vehicle stability and aborting incipient sway events. These systems work very much like modern stability control systems on aircraft. The systems are always on and act instantly to mitigate tow vehicle and trailer stability problems. In my opinion these systems do a much better job handling vehicle stability problems, such as sway, than these crude last century heavy weight distribution systems. For now the belt and suspenders approach is to have both. This a prudent approach.
It is interesting to follow the evolution of these stability and control systems. I have followed Ford's approach and have little knowledge about the systems by other manufacturers. Everyone towing a trailer should use a tow vehicle with a automated electronic sway control system that is always active.
Here is the AI review of the evolution of Ford's sway control system. I have personally expereinced an aggressive, manually induced sway event (to avoid road debris) and then experienced the Ford Electronic Trailer Sway Control (TSC) system take over control of the truck and stop the sway, before I could sense the situation and begin to react. It Works.
The note to me at the end of the Google Gemini review is the key. You can fiddle with all the details of setting up the tow vehicle, trailer and various mechanical aids. But it is likely the automation will save the day, if all that fails. But you need tow vehicle with an always on towing stability control system.
Google Gemini Review of the Ford Systems:
Ford’s electronic Trailer Sway Control (TSC) was a landmark safety development in the truck industry, marking the transition from purely mechanical solutions (like friction bars) to integrated software-driven stability systems.
The history of this system is tied directly to the evolution of Ford’s AdvanceTrac and Roll Stability Control (RSC)technologies.
1. The Genesis: AdvanceTrac and RSC (Early 2000s)​
Before a dedicated "trailer" system existed, Ford focused on vehicle stability. In the early 2000s, Ford introduced AdvanceTrac, their version of Electronic Stability Control (ESC). In 2005, they added Roll Stability Control (RSC), which used a gyroscopic sensor to monitor the vehicle's roll rate. This laid the hardware foundation (sensors and ABS integration) necessary to eventually detect and counteract the lateral "pendulum" effect of a swaying trailer.
2. The Breakthrough: 2009 F-150​
In 2009, Ford introduced the industry's first integrated electronic Trailer Sway Control as a standard feature on the F-150.
  • The Innovation: Unlike previous systems that only monitored the truck's behavior, the 2009 system was programmed to specifically recognize the "yaw" (side-to-side) oscillations unique to trailer sway.
  • How it changed towing: Before this, drivers relied on manual trailer brake controllers or mechanical friction-sway hitches. The 2009 system automated this by sensing sway and automatically applying precise, asymmetric braking to individual truck wheels and reducing engine torque to pull the trailer back into line.
3. Expansion to Super Duty and SUVs (2011–2013)​
By 2011, the technology was standard across the Super Duty (F-250/F-350) lineup. During this era, Ford also integrated the Factory Trailer Brake Controller (TBC) more deeply into the software. If a trailer with electric brakes was connected, the Sway Control system could now pulse the trailer's brakes in addition to the truck's brakes to provide even faster stabilization.
4. Integration and "Smart" Features (2015–Present)​
With the launch of the aluminum-body F-150 in 2015, the system became part of a larger "Smart Trailer Tow" ecosystem:
  • Pro Trailer Backup Assist (2016): While not an anti-sway system for highway speeds, this used the same sensor logic to manage the trailer's angle while reversing, preventing jackknifing.
  • Dynamic Hitch Assist: Added camera-based lines to help align the ball with the coupler, ensuring a more secure connection (which is the first defense against sway).
  • Blind Spot Information System (BLIS) with Trailer Coverage: Expanded the truck's sensors to "see" the length of the trailer, further aiding stability during lane changes where sway is often triggered.
Summary of System Operation​
Ford’s system remains a "reactive" safety net. It continuously monitors the truck's yaw motion at a high frequency. If it detects the tell-tale oscillation of a trailer:
  1. Braking: It applies "asymmetric" braking (e.g., braking the front left wheel to counter a rightward sway).
  2. Power: It reduces engine torque to slow the entire rig.
  3. Alert: It flashes a "Trailer Sway Reduce Speed" message on the productivity screen.
Note: As someone who monitors aerodynamic efficiency and "towing taxes," you'll know that while this system is a lifesaver, it doesn't replace proper weight distribution. It is designed to intervene when physics (wind, emergency maneuvers, or poor loading) overcomes the mechanical setup.
Turbopilot you intrest me.
Using a biased AI review.
How?
It's all in the question. Asking AI for information exclusively about a Ford system, will give Fords literature. Want AI opinion on lightship ask about lightships system! Your quite the sales man when talking to people that have no idea how AI works.
It is possible to select your tow vehicle and load it and the trailer properly so that you will never have sway. Electronic sway controls are fine as a back-up, but if they ever activate during normal towing it indicates that something is wrong. Usually that means your tow vehicle is too small for the trailer, or the trailer is designed with not enough tongue weight for the speed you want to travel at. Tire pressures are also critical.
Not true. My system was perfectly set up. I initiated an aggressive move to avoid road debris and associated damage. What followed was about 1 1/2 cycles of significant trailer sway before the F-150 took over and aborted the sway event.
Sway can be initiated by many factors. You can force sway in a perfectly set up tow vehicle and trailer if the input is aggressive enough. Once that fast cycle phugoid oscillation begins you want to stop it before the oscillation is extreme. An automated system can arrest the oscillation much quicker than the typical human reaction time.
I would argue an always on, automated sway control system is the first line of defense to protect a perfectly set up tow vehicle and trailer or to protect an idiot who has done nothing to to set up the system to prevent vehicle stability problems.
In today's world, if you don't know how AI works including the benefits and the short comings, you are going to have a disappointing rest of your life. I have found AI gets right more often than the typical forum poster. But that low bar of performance does not take much to overcome.
You are towing an 8000 lb. trailer with a 5000 lb. truck. It's going to sway when you go over 60-70 MPH. You need an 8000 lb. heavy duty pick-up. I'm sure that will solve the sway problem make for a much safer and more comfortable tow.
You best consult AI before posting. This is exactly the problem we are having in these discussions. The resident pundits immediately type stuff originating from their restricted fund of knowledge and experience. Most often before I type anything these days I test my knowledge and memory with AI. Our discussions would be much more helpful to other people if everyone did the same. None of us are as smart as the collective wisdom of many.
My F-150 PowerBoost is a 7,350 lb truck.
From AI. I have never seen a 7,400 PowerBoost so AI may have this wrong but close.
The 2024–2025 Ford F-150 PowerBoost (hybrid) typically has a Gross Vehicle Weight Rating (GVWR) of 7,350 to 7,400 lbs. As the heaviest F-150 configuration, its curb weight is approximately 5,500+ lbs, leaving a payload capacity around 1,700–1,800 lbs. Always check the door jamb sticker for exact ratings.
Key Weight Specs for PowerBoost:
  • GVWR (Gross Vehicle Weight Rating): Generally 7,350–7,400 lbs.
  • Curb Weight: ~5,517–5,540+ lbs (varies by trim/options).
  • Payload Capacity: Max is ~1,735–1,830 lbs.
  • Towing Capacity: Up to 12,700 lbs.
