newmarokie
- Oct 8, 2023
- southern oklahoma
- newmar
- Dutch Star 4018
- 40'
- Freightliner
- 450 hp Cummins
- 2017 Colorado, 2013 Dodge 1500 quad cab
Okay, I know it is not making fluid. I have the wet bay torn apart replacing tees, elbows, and valves. I had the pressure off of the system for about 75% of the time. When I check in the morning for leaks one of my leaks was the overflow tank overflowing on the Oasis. I put a clean jug under the overflow tube and left it overnight. The next morning the 2.5 quart jug was brim full. I siphoned about 3 quarts out of the overflow tank and started the Oasis and let it warm to temperature. I siphoned another quart of fluid out. I turned the fresh water off and left it overnight. This morning it was up another 1 1/2". I took the radiator cap off of the tank and it had light pressure on it and was completely full. With the system powered completely down the domestic pump was running. They only two things I can think of that is happening is (hopefully) a bad radiator cap or a bad heat exchanger. I am under the impression that the heat exchanger is two completely separate lines running through the aluminum fins so there can't be any incursion between systems. I am going to try to get the radiator cap replaced locally and see if that cures the problem. Any thoughts or advice would be appreciated.
