Question Torque and Bras
leemd3
Hi, I have two questions, we have a 2026 Holiday Rambler Admiral on the Ford F-53 Chasis with the 7.3L V8 engine.
1. We seem to be having trouble with the torque even when going up a slight incline, we arr not towing anything and we only have two people and minimum supplies. Did I mention we have less that 1,000 miles
2. can anyone help me find a reasonable priced grill bra for the coach I dont want to pay 900+ to cover an 18inch opening just to keep the bugs out of my engine compartment?
Thanks
Leemd
What kind of trouble, are you climbing in cruise?
Thanks
Leemd
Waht model, size is your coach? At what altitudes are you driving at? What are you using for fuel?
The engine is till breaking in so you want to avoid full throttle low RPM operation a bit. At altitude you loose 3%HP for every 1,000 feet.
Trans should downshift to compensate..is it not dropping a gear or 2?
Hey thanks for the reply and the infor, it is a 2026 Holiday Rambler Admiral, 31 footer. Not driving at high altitudes. I will give it more time as we drive and hopes it does better. But I will keep in mind about the altitude. Thanks again
That's whatbI thought and it did not feel like the trans was downshifting so that is what had me concerned.
You should feel it downshift. Look at your tach..rpm should jump up especially if it drops 2 gears.. mine cruises around 2300 rpm but jumps to 3000 rpm if it goes from 6th to 4th on a steep incline
No I am not climbing in cruise, just trying ti maintain whatever speed I was at before starting the incline
Unfortuntely gravity, your MH's gvw and your 6 speed V8 aren't going to play well going uphill. Dial it back a notch or two, adjust your expectations and it will all be good. Wait 'til you hook a 5k lb. toad back there.
That is good to know at least i know what to expect thanks for the response
Do you get a running start? If I a see an incline ahead I will usually increase speed a bit to give me a bit more oomph.
