Question Torque and Bras
You would've got there eventually. ;)
In bike riding, the 'peloton' leaders, that's the long line of riders drafting behind the leaders will deliberately not increase the speed before beginning a short climb so as to rob the bigger guys of the momentum advantage.
Thats what big trucks do too..it helps climbing with loads
It's called driving, engine brake downhill, power pedal 3/4 way down for uphill
Driving with a load..you dont need a running start in a 400 hp car
Hi, I have two questions, we have a 2026 Holiday Rambler Admiral on the Ford F-53 Chasis with the 7.3L V8 engine.
1. We seem to be having trouble with the torque even when going up a slight incline, we arr not towing anything and we only have two people and minimum supplies. Did I mention we have less that 1,000 miles
2. can anyone help me find a reasonable priced grill bra for the coach I dont want to pay 900+ to cover an 18inch opening just to keep the bugs out of my engine compartment?
Thanks
Leemd
Hello. I have a 2020 Admiral 32S with the V-10/6-speed and do not seem to have that trouble. I would imagine the torque on the V-8 improved so maybe you are referring to the downshifts while using cruise control. I only have about 6K miles on mine and have only driven it 1/2 across the country (17 hours straight) to bring it home and one camping trip so far. What I did notice is that cruise control increased downshifts and was way worse in fuel consumption than me using the gas pedal with a light foot. When the cruise control would down shift, I would disengage and drive grades with a light foot until I was on level freeway. Maybe that is the issue you are dealing with.
(Off Topic here) Only issues I have has so far with the HR is PEX hose under kitchen cabinet rubs while the slide moves, this put a pin hole in the hose and caused a leak (fixed by Handyman at RV resort) so I will zip tie a clear hose over it for protection. I also noticed the lights in bedroom seemed to go dim. I found the rocker switch for lights is also a dimmer, so not a bug but a feature. So far I am happy with my purchase and hope you are too. Hope this helps.
I don't have your particular rig but towing my trailers when coming to a hill I manually down shift to approach the hill at a higher rpm
